Old 27-03-2007, 04:50 PM   #1 (permalink)
MVP Awardee 07
uzair's Avatar
Exclamation "Hard disk Failed Press H to retry or enter to boot from other device "
I purchased my lenovo 3000c100 during may of 2006..
Yesterday when i switched it on...it went into a long bklank state.then came the message
Is it the end of the laptop.Later when i switched it on 15 mins later...It turned normal again..i could see the os choices and everthing went normal..When i restarted it again it was unable to boot showing the same messga again..
Can a hard disk not so old crash this early...??Is it the hardware or is it some virus denying access to the boot sector..coz when i was in my account i noticed empty copy of the folder i am in..On clicking that i go into explorer mode.??
Virus or Hardware's out????
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
uzair is offline
Old 27-03-2007, 05:29 PM   #2 (permalink)
Default Re: "Hard disk Failed Press H to retry or enter to boot from other device "
IT must be under warranty if u bought in may 2006, get it checked.
It may be faulty IDE cable which at times is working & other times denying to boot.
ranjan2001 is offline
Old 27-03-2007, 05:35 PM   #3 (permalink)
MVP Awardee 07
uzair's Avatar
So are you sure the hard disk's all right...
uzair is offline
Old 27-03-2007, 05:49 PM   #4 (permalink)
No I cant say say that all is fine with HDD but if its gone bad, then it would have shown you signs of faliure, the comp starts hanging, you would have to do hard boots.....................................in ur case seems some other issue......................u have the warranty get it to lenovo.
Old 27-03-2007, 06:06 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
hey,have you installed any other OS ?make sure your hard disk is setup to first booting device.It may be possible that ur boot loader file has been crupt.Try fixing the boot loader file using bootloader(google it)
ravi_9793 is offline
Old 29-03-2007, 04:20 PM   #6 (permalink)
MVP Awardee 07
uzair's Avatar
Cool Re: "Hard disk Failed Press H to retry or enter to boot from other device "
^^^Yes the hard disc has four partitions...Three of them contain winxp pro,home,mediacenter respectively...
Pro and home don't work..Currently i'm using media centre...
Also yesterday when i turned on the system everthing came up jus fine..i restarted and everything was fine...
i googled bootloader which one to download.???
uzair is offline
Old 29-03-2007, 06:06 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
If everything is working fine now..than why you want to do some tweaking???
Old 01-04-2007, 12:33 AM   #8 (permalink)
Could be a possibe hdd crash which resulted in bad/corrupted sectors .To be on the safe side , do an error check of your primary partition.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
"Login failed" on Yahoo! Go for mobile?? nikhilpai Mobiles and Tablets 12 09-03-2007 11:04 AM
"8-bit palleted textures" marked failed Chetan1991 Software Q&A 1 29-01-2007 04:04 PM
Windows cannot find "rose.exe" error, when accessing Hard disk drives ! vishesh8 Software Q&A 14 11-01-2007 10:01 PM
My "HARD DISK" Board Failed muralikrishnan Hardware Q&A 1 16-02-2006 11:48 AM
