memory controller probe??
im using athlon 64 3000+ (939)
gigabyte geforce 6150/nforce430 mobo
there is problem with my memory modules
im having 1. kingston 256mb ddr400 3-3-3-8
2. kingston 256mb ddr400 3-3-3-8
exactly same modules
3.transcend 512mb ddr400 2.5-3-3-8
4.oem samsung 128mb ddr266 2-3-3-7
3.& 4. i got from my old p4 845
problem is 1. when i use 2 X kingston 256mb ddr400 3-3-3-8 memory controller runs at 512mb dual channel 128 bit 3-3-3-8 at 400mhz
2. when i use 2 X kingston 256mb ddr400 3-3-3-8 & transcend 512mb ddr400 2.5-3-3-8 memory controller runs at 1024mb single channel 64 bit 2.5-3-3-8 at 333 mhz
3. when i use 2 X kingston 256mb ddr400 3-3-3-8 & transcend 512mb ddr400 2.5-3-3-8 & samsung 128mb ddr266 2-3-3-7 memory controller runs at 1152mb single channel 64 bit 2.5-3-3-8 at 266 mhz
which one of the above combinations do you folks think gives best performance
512mb dual channel at 400mhz
1024mb single channel at 333 mhz
1152mb single channel at 266 mhz
idont game a lot
athlon 64 3000+ (939) gigabyte geforce 6150/nforce 430 mobo seagate sata2 80gb x 2 in raid 0 audiligy value2 altec lansing mx5021 samsung syncmaster 940BW sony dru-120c dvd burner liteon 5236v combo sony cdrom
