Old 26-03-2007, 03:19 AM   #1 (permalink)
Question Heat sink
Hi i just got a Asus P5NE-SLI Board,And want to Add Heat sink for North/South Bridge Can any one suggest where i can Buy it In Delhi,and what will be the price. Should i Go for with fan Or without fan. Thanks
saurabh DH is offline
Old 26-03-2007, 07:33 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Heat sink
For sure you should search in nehru place.Some of the good company producing heat sink are Aero Cool, Cooler Master, Foxconn, Thermalright, Thermaltake, Swiftech, and Zalman.
ravi_9793 is offline
Old 27-03-2007, 07:52 AM   #3 (permalink)
I don't think that good Heatsinks are not available in delhi (nehru place). If i am wrong please correct me. Also good HSF for chipsets is a dream in India.
longlife is offline
Old 27-03-2007, 09:23 AM   #4 (permalink)
darklord's Avatar
You can order through www.sidewindercomputers.com
Thermalright HR-05 is an excellent chipset cooler and should keep the 650i SLI chipset pretty cool
darklord is offline
Heat Sink holder cooldip10 Hardware Q&A 6 26-02-2007 12:33 PM
Heat sink paste... Kniwor QnA (read only) 2 02-10-2005 04:41 AM
What is Socket Notification Sink? Help my Plzz :( stalin QnA (read only) 2 27-05-2005 04:47 PM
the processor stuck to the heat sink ....... Omsck CPU / Motherboards 2 26-03-2005 09:19 AM
Heat Sink - your view icecoolz QnA (read only) 13 07-12-2004 12:44 PM
