Old 26-03-2007, 12:22 AM   #1 (permalink)
slash_89
Posts: n/a
Exclamation RAM problem.
i recently purchased a ddr2 667mhz transcend ram,
but when i checked its frequency in cpu-z its reporting 334mhz
has my dealer cheated me?
uve even changed the bios settings to 667mhz but to no avail
and i have an amd athlon64 x2 3800+ processor,
sisoft sandra pro max 3 doesnt work,
should i download the 64 bit version?
and can i install vista ultimate 32 bit version?
Old 26-03-2007, 07:46 AM   #2 (permalink)
Default Re: RAM problem.
There shouldn't be any problem. Since it is DDR, it operates @ double the frequency.
V.Prem Kumar
janitha is offline
Old 26-03-2007, 08:01 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
DDR stands for Double Data Rate. 333.5x2 = 667MHz
Your RAM is running at the proper speed CPUz will always detect the actual.Not to worry anything.
ravi_9793 is offline
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
