Old 24-03-2007, 12:29 PM   #1 (permalink)
slash_89
Posts: n/a
Exclamation Final Decision.
Hi guys,
I had already posted a thread regarding a configuration,
Config:-
AMD
Athlon64 X2 3800+ (Socket AM2)
512MB DDR2 667MHz RAM
Now the mainboard that was suggested was the Asus M2N-MX
I was thinking of going with the Asus M2N PV-MX
Am I right in going for the Asus M2N PV-MX board?
Is this a quality board, does it have any snags or drawbacks?
Is Asus M2N PV-MX better than the Asus M2N-MX board?
And what is the chipset + features of this board?
And will this config :-
AMD Athlon64 X2 3800+ (Socket AM2)
Asus M2N PV-MX
be able to play Rise Of Nations flawlessly and very well?(important Q)
will it be able to handle Vista very well?(with 1GB of RAM)
Old 24-03-2007, 04:47 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Final Decision.
vista might ba litle slow...
the config can play rise of nations well
Tech Geek is offline
Old 24-03-2007, 05:16 PM   #3 (permalink)
assasin's Avatar
diff bet M2N PV-MX and M2N-MX is that the former has 6150 IGP and the latter has 6100 IGP.diff in performance is bout 5% and price diff is bout 1k.so its better to buy M2N-MX.
RON will run well but Vista will be a bit slow because the ram will be shared.
assasin is offline
