Old 24-03-2007, 12:15 PM   #1 (permalink)
No longer here..
Default Regarding mobo supporting CPU ..
I came across this mobo MSI 865GM3-LS .. the webpage http://www.msi.com.tw/program/produc...il.php?UID=598
says the "Supports up 3.4GHz and higher speed P4 processor" .
Does it mean a 2.8Ghz HT P4 prescott wont run on it ??
indian_samosa is offline
Old 24-03-2007, 12:50 PM   #2 (permalink)
digiFriend's Avatar
Default Re: Regarding mobo supporting CPU ..
MSI 865GM3-LS:
Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.4GHz and higher speed P4 processor.
• Support HT
this motherboard will support 2.8Ghz HT P4 prescott .
you never know what you can do until you try
digiFriend is offline
