Old 23-03-2007, 05:06 PM   #1 (permalink)
Angry Why hard disk drive as removable drive?
Hai there
Why my 80GB seagate 7200 RPM hard disk drive is showing as removable drive (under safly remove icon in system notification area) in my windows XP SP2 system powered by AMD Athlon 64 bit 3000+ and ASUS motherboard.
Sheik Rasheed K is offline
Old 24-03-2007, 01:10 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Why hard disk drive as removable drive?
It must be SATA disk ............right. Then just ignore the notification by windows, as it treats SATA HDD as hot swappable.
john_the_ultimate is offline
Old 24-03-2007, 01:27 AM   #3 (permalink)
www.indianangler.com
saikibryan's Avatar
SATA II drive recognised as removable, as these r hot swapable...no need to worry
when the going gets tough, the tough go.....fishing!!!
saikibryan is offline
Old 24-03-2007, 09:32 AM   #4 (permalink)
dOm1naTOr's Avatar
@Sheik Rasheed K
No problems yaar. It appears if u install the sata drivers also during the mobo chipset installation. The installation replaces default sata drivers. U can't select safely remove ur HDD coz it says 'access denied coz its in use now'.
Do ya have any nforce mobo?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-03-2007, 07:17 PM   #5 (permalink)
Thanks Friends, But my friends' hdd also sata, then why his pentium powered system does not show the hdd as removabe.
Old 25-03-2007, 01:18 AM   #6 (permalink)
dOm1naTOr's Avatar
@Sheik Rasheed K
His mobo is an intel chipset one. They dun show HDDs as removable storage.
Ive only seen this in nforce mobos and itll show only if u select 'SATA Drivers' also during chipset driver installation. But what is the problem with it yaar. Just leave it. It won't make any harm.
G3: XPS M1530 |
FZ 16.
Old 25-03-2007, 10:01 AM   #7 (permalink)
coolsunny's Avatar
i do think u intalled storage drivers from motherboard cd..
To remove safty removal icon from taskbar u have to reinstall motherboard cd.
not the whole but where there is a option of storage driver.Just uncheck the box & install.it will not do any harm.
by the way which mobo do u using???
Reply if it works...
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
