Re: 2gb ram
@goobimama
instead of going for a single 512 more, get 2x256 along with ur current one and ull get 128 bit 800MHZ 1.5GB dual ch mem.
@xbonez
I dun think u can see any big difference in ingame perfomance as ur can wud be a big bottleneck. That means the low perfomance is due to the card and most other components in ur PC can work better in gaming, but they are limited by the slow GPU. U can see a BIG BIG difference in performance if u were using some cards higher than 7900GS or GT.
But ull surely get a boost in loading times as quick loads will take less than a second. And doing as @NikhilVerma said will be great for gaming, but if ur PC goes OFF[no time to shut down] due to any power failure then there is more chance for data corruption as the whole data which was on RAM will be lost and there ll be no copy of it in virtual memory to restore during checkdisk.
G3: XPS M1530 |
FZ 16.
