Old 22-03-2007, 09:49 AM   #1 (permalink)
Pravas's Avatar
Question Which One's Best?
Hello guys, can anyone tell me which is the best processor AMD or INTEL for animation purpose. ANd please also gimme some info about Motherboards.
!!!!*Little Knowledge Is Dangerous*!!!!!
Pravas is offline
Old 22-03-2007, 10:42 AM   #2 (permalink)
Tech Geek's Avatar
Default Re: Which One's Best?
Go for Intel C2D and motherboard--Intel D965RY Rs7000
Tech Geek is offline
Old 22-03-2007, 10:44 AM   #3 (permalink)
assasin's Avatar
the best processor available today is the Intel Core2Duo.u can choose any proccy from the c2d range.
if u wanna oc ur proccy then Asus P5N-E sli will be a good mobo.
assasin is offline
Old 22-03-2007, 12:14 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yaa..C2D is better option than AMD if U dont have budget problem.Than for MB go for intel965..
ravi_9793 is offline
Old 22-03-2007, 02:34 PM   #5 (permalink)
aj27july's Avatar
intel is the best.
and with the advent of dual core processors, intel is still the better one.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 22-03-2007, 05:26 PM   #6 (permalink)
assasin's Avatar
Originally Posted by aj27july
intel is the best.
cant agree with u on this one.C2D is the only proccy from Intel which is better than any other proccy of AMD.but other proccy from Intel like P4 and pentium D r not as good as their AMD counterparts.
assasin is offline
Old 22-03-2007, 06:08 PM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
I'd agree with assasin here, untill C2D. AMD was winning hands down with their Pocessors with better performance, less heat and power but with C2D intel has won the battle with better performance in all 3 catagories.
To the OP go for C2D and make sure you have oodles of RAM if you are in to animation or video editing.....
sam9s is offline
Old 23-03-2007, 06:35 AM   #8 (permalink)
Motherboard : Intel D965WH Rs 7100
abhipal is offline
Old 24-03-2007, 01:43 AM   #9 (permalink)
www.indianangler.com
saikibryan's Avatar
assassin is right, intel has turned tha wave into their favour with C2D proc...before that it was AMD64 for AMD...now waitin for AMD to fire back...
when the going gets tough, the tough go.....fishing!!!
saikibryan is offline
Old 24-03-2007, 02:36 AM   #10 (permalink)
aquamatrix's Avatar
get a c2d with atleast 2 gigs of ram.
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
