Old 20-03-2007, 10:34 PM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default AGP Drinks power? really...
Okay a lil Question... for the peace of my mind (and to win a lil wager) he he
I have AGP card "GeForce 6800 GS"... it needs two "Molex connectors"
My fren was telling me "this CARD is power hungry" (which i know... come on two molex... i get the clue )
But then he further added "These CARD keep on drinking power"... that got me worried
Is that like... TRUE?
I thought the card will only DRAW according to it's need:
* Like when I'm using internet or typing in WORD it should take MIN
* And when i switch on DVD movie or Games... it shall MAX... isn't it so?
HELP !!!
gsoul2soul is offline
Old 20-03-2007, 10:44 PM   #2 (permalink)
assasin's Avatar
Default Re: AGP Drinks power? really...
yeah power consumption reaches max limits when ur gaming at max limits of the card.at other times power consumption is less.
assasin is offline
Old 20-03-2007, 11:49 PM   #3 (permalink)
deathvirus_me's Avatar
It requires two molex or a single 6 pin power connector ??? Ok , lets put this simple .. at idle state , the card does get enough juice from the slot itself ... under heavy load , the card "consumes" from the power connector ...
deathvirus_me is offline
Old 21-03-2007, 09:11 PM   #4 (permalink)
dOm1naTOr's Avatar
@gsoul2soul
its not with AGP but the family of ur GPU, that the power consumption depends on.
A newer core consumes much less power that a similar perfomance older family GPU. Like a 6800GT and a 7600GT are similar performer. 6800GT needs much power and needs 2 power connectors whereas 7600GT dun need any external connector at all. The 8 series is better power efficient.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 21-03-2007, 09:21 PM   #5 (permalink)
Originally Posted by aravind_n20
@gsoul2soul
7600 gt agp does indeed need have one power molex connector ..
yogi_7272 is offline
Old 21-03-2007, 10:05 PM   #6 (permalink)
WOW... are you?
gsoul2soul's Avatar
It has two molex connector.... but both have 1 pin missing in each
So that makes "6 pins" in total... so instead of using two molex i can use some other plug ? "6 pin power connector "... like death virus mentioned ?
Old 24-03-2007, 01:10 PM   #7 (permalink)
dOm1naTOr's Avatar
@gsoul2soul
No, itll either have 2 molex or a six pin connector. Both are different.
G3: XPS M1530 |
FZ 16.
