Old 20-03-2007, 06:38 PM   #1 (permalink)
Exclamation Viewsonic VA1703W 17" Wide Monitor
Hi Guys,
I just bought a Viewsonic VA1703W 17" Wide Monitor which was supposed to give me a great widescreen 16:9 ratio experience. I fell for the ads but
sadly all I can see is that everything is still 4:3 and looks stretched horizontally.
I cannot find the 1440x900 resolution on my system. Could this be a graphics card issue?
I have a Tiga TI810+S motherboard with an inbuilt Intel 810 graphics and using Windows XP Home Edition. Is this the problem. Will i have to get a PCI graphics card? Which card will support this resolution or any resolution with 16:9 ratio instead of 4:3 ratio? Will I have to update the BIOS?
Please Help. The Viewsonic engineer went away scratching his head too!
ashwns is offline
Old 20-03-2007, 06:46 PM   #2 (permalink)
Default Re: Viewsonic VA1703W 17" Wide Monitor
Yes you need a graphic card, not necessarily the PCI , even agp will do but, all nvidia cards supports & auto detect the widescreen.
Dont you read post here there are so many discussions on this subject, dealers don't tell this info to buyers & later you feel cheated, You will now have to shell out 3-4K for a graphic card. Wide screen requires special graphic cards which can run it on custom resolution.
ranjan2001 is offline
Old 20-03-2007, 10:33 PM   #3 (permalink)
i was also planning to buy widescreen some time in future.
i have onboard nvidia 6150. will it detect widescreen??
varunprabhakar is offline
Old 20-03-2007, 10:42 PM   #4 (permalink)
should be able to, you may have to update the driver to latest.
Its a feature of the nvidia drivers.
Old 20-03-2007, 10:45 PM   #5 (permalink)
thx. was tensed tht didnt want to save another 3-4k to use a widescreen lcd!!
Old 20-03-2007, 10:51 PM   #6 (permalink)
http://www.nvidia.com/object/custom_resolutions.html
This gives u all details, but on 2nd thought it may not if the onboard uses different kind of drivers, so check it before u buy.
Old 21-03-2007, 03:56 AM   #7 (permalink)
aquamatrix's Avatar
sad but 810 mobo's dont have a agp or a pci-e slot, only pci slots
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 21-03-2007, 04:03 AM   #8 (permalink)
Learner
Kniwor's Avatar
Dont worry 6150 will handle it just fine.
Kniwor is offline
Old 21-03-2007, 04:07 AM   #9 (permalink)
 Macboy
goobimama's Avatar
Hey I have a 915GAV board and my Dell widescreen worked perfectly at 1920x1200. No issues at all. Though I must admit, the 810 board is really outdated...
And as for your screen ratio, it isn't 16:9, but 16:10
I'm like a bird... :)
goobimama is offline
Old 21-03-2007, 06:58 AM   #10 (permalink)
nishant_nms's Avatar
get ur PC upgraded because there is very less chance of getting a PCI gfx card
nishant_nms is offline
Old 24-03-2007, 04:12 PM   #11 (permalink)
ayush_chh's Avatar
i hav the same monitor. my mobo is 945dv...no graphic card...supports 1400x900...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 26-03-2007, 09:11 AM   #12 (permalink)
Hulo's Avatar
I too have a P-III with a i810e motherboard and an onboard 4 MB AGP. I want to buy a 17" or 19" TFT monitor (non-widescreen). Will my board support the monitor? If so, which will be the best model?
Join IGNOU MCA Students' Forum -- http://www.santanu.in
Hulo is offline
Old 28-04-2007, 11:29 PM   #13 (permalink)
Hulo's Avatar
Hmm... so my 810e will not work either. Regrading PCI Graphics card, are these still available?
Don't know why the engineer went home scratching his head. This is only expected. Still I'd request you to try this driver -
http://www.viewsonic.com/drivers/Sta...ned_070410.ZIP
This is from the viewsonic website. Let me know the results. Also, can you let me know how much you paid for the monitor? I am thinking of purchasing one too. But I have to go for a non-widescreen one. But most shops keep only widescreen ones.
Hulo is offline
Old 03-05-2007, 08:09 AM   #14 (permalink)
Hulo's Avatar
Just to inform you guys... I ultimately bought a Viewsonic VG921m 19" monitor @Rs.11648 from M.D. Computers at G.C. Avenue, Kolkata. This is a standard model, not a widescreen one. Running it on an old P-III 800 MHz PC with Intel 810e chipset and onboard graphics. After installing the viewsonic monitor driver I'm getting the recommended resolution of 1280x1024 @75Hz. Didn't know my card was capable of handling this.
Hulo is offline
Old 03-05-2007, 11:46 AM   #15 (permalink)
 Macboy
goobimama's Avatar
The thing is with a 4:3 19inch LCD, you get the same resolution as a 17inch 4:3...
Old 03-05-2007, 11:31 PM   #16 (permalink)
Hulo's Avatar
..but the display in the 19" monitor would look better and bigger than that in the 17" monitor at the same resolution.
Hulo is offline
Old 21-05-2007, 07:37 PM   #17 (permalink)
Fast 'N' Furious
topgear's Avatar
I have an Geforce 5200 GFX card. Should I buy 19 inch widescreen LCD?
Will the card support 1440*900 resolution
I am asking it it again to kick out the fear of compatibility issue from my mind
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 21-05-2007, 11:50 PM   #18 (permalink)
Check this out .
GeForce FX 5200 Ultra and 5200 GPU Specifications
Dual RAMDACs (up to 400 MHz) for display resolutions up to and including 2048×1536 @ 85Hz
more at http://www.nvidia.com/page/pg_20040109440047.html
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 23-05-2007, 08:32 PM   #19 (permalink)
Fast 'N' Furious
topgear's Avatar
To Eliminate the issue of widescreen supported graphics chips- look at here:
http://ap.viewsonic.com/in/kbase/article.php?id=8
Will text be readable perfectly on 19 inch widescren monitor #1440*900
topgear is offline
Old 23-05-2007, 10:55 PM   #20 (permalink)
The 5200 GPU supports display resolutions up to and including 2048×1536 @ 85Hz which means it will support 1440*900 resolution.
any possibility that u can get a demo from ur dealer ?so that you are on the safe side .
Old 24-05-2007, 05:28 AM   #21 (permalink)
Fast 'N' Furious
topgear's Avatar
I don't think i will get a chance for see a demo of monitor. so i have to rely on you guys.
also
will text be seen perfectly readable on a 17 inch tft (1280*1024) res with windows default 96 dpi.
topgear is offline
Old 25-05-2007, 05:26 PM   #22 (permalink)
hey i brought lg 17 inch lcd l1752s for 9000 rs i think itwares r vry expensiveeeeeeeeeee
hackers2005.3721 is offline
Old 27-05-2007, 05:33 AM   #23 (permalink)
Fast 'N' Furious
topgear's Avatar
Finally got ie bought viewsonic VG921M 19 inch LCD TFT (not widescreen)
topgear is offline
Old 28-05-2007, 12:00 PM   #24 (permalink)
Uff. I gave up and went and bought (actually exxchanged) my widescreen to a standard monitor.
But overall a bad experience.
ashwns is offline
