Old 19-03-2007, 06:29 PM   #1 (permalink)
Default Help me with my upgrade?
Hi guys, I asked one of my computer guys to assemble a computer for me, as I do not know much about hardware (im mostly in software). This is what he gave me
-Pentium IV Dual Core 3.0 GHz + 915 Dual Core Compatible Intel Motherboard - Rs 16,000
- 1 GB DDR II RAM - Rs 5,000
- 120 GB SATA HDD - Rs 4,000
- DVD Writer - Rs 2,000
- 128 MB AGP Graphic Card - Rs 2,500
- 17" TFT Monitor - Rs 12,000
Total Rs 41,500 approx
Now, the budget is just about right for me. However, I wanted to know if its possible to have a better configuration for the same budget. I was think of Core 2 Duo, but I am not sure what exactly the difference is between Dual Core and Core 2 Duo? Also, is 16,000 is bit too high? Could you guys tell me what exactly the mobo and processor I should go for?
Also, I was hoping for atleast 160 GB Hard drive, and a slightly better Graphic Card. I wont mind going for 15 " TFT instead of 17 " to save a couple of thousand.
Can anyone tell me what exactly I should go for, and if this upgrade is ok? Or something that could be better within the budget.
Thanks
hitman050 is offline
Old 19-03-2007, 06:46 PM   #2 (permalink)
assasin's Avatar
Default Re: Help me with my upgrade?
OMG!!! ur vendor is a ROBBER!!!!
Pentium D 3ghz + mobo = 16000???? even C2D with a 945 chipset mobo wont cost u that much
120GB hhd for 4000????? 320GB SATAII cost less than that.they cost bout 3850
1GB DDRII sud be bout 4.2k
17"TFT sud be 10.2-10.5k
go for C2D E6300 + any good 965 chipset based mobo,1GB DDRII,320GB HDD or 2*160GB if u wanna setup RAID 0.u can buy 7300GT 512MB sud be bout4.5-4.8k.all these sud come in ur budget sud cost u below 41.5k.
Both Pentium D and Core@Duo (C2D) r dual core processors,but C2D is far better than Pentium D mainly due to its new architecture.
assasin is offline
Old 19-03-2007, 06:59 PM   #3 (permalink)
Thanks mate, you just saved me from getting looted
I was looking around, and I found this? What do you think of this configuration, and how much would it cost now?
http://www.techarp.com/showarticle.a...tno=368&pgno=4
Also, my vendor was telling me that I can only have max 160 GB HDD, as a higher one requires a much more powerful system which can go into 90,000? This is bs isnt it? Also whats difference between IDE or SATA?
Also, the pc I will buy, will it be good enough to play modern games at decent framerates? Is there any site where I can see Indian prices for computer components. I think Ebay is a bit overpriced.
Thanks, I love these forums
Old 19-03-2007, 07:21 PM   #4 (permalink)
aquamatrix's Avatar
wtf??
dude the prices are way too high. To check the latest prices check out these links
www.mahavir.co.in or www.deltapage.com
__________
and dump that vendor
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 19-03-2007, 07:21 PM   #5 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Utter non-sense. This reminds me of the Ritchie street guy who wanted to charge me more for an Athlon 2800+ because I asked for a "Athlon 2800" but he had stocked only "Athlon 2800+" (which he beleived to be an enhanced version of "Athlon 2800" ).
Try these sites
http://deltapage.com
http://theitdepot.com
http://computerwarehousepricelist.com
http://npithub.com
http://www.mahavir.co.in
SATA drives are theoretically faster than IDE drives.
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 19-03-2007, 07:28 PM   #6 (permalink)
assasin's Avatar
To say the truth either ur vendor is a idiot or he's a crook.who said 160GB cant be used with ur config?u can use a 750GB hdd with ur config.any modern pc can run a 750GB.
se my rig's config in my signature.i've 2*160GB in RAID 0 and i certainly dont hav a 90k rig .
go for SATAII hdd,they r better than IDE ones.
as far as the gaming part is concerned,i'll suggest u wait 4 a few more months and buy a 8600 series DX10 gfx card.
that config u hav selected is a gr8 one but it'll be a little hard on ur pocket.if u hav a budget of 50k plus then u can think of buying that pc.
assasin is offline
Old 19-03-2007, 07:29 PM   #7 (permalink)
Thanks for the help guys. So, what do you suggest I can get within the same budget or even less?
Old 19-03-2007, 07:40 PM   #8 (permalink)
mod-the-pc's Avatar
At the same budget you can get a better rig or get the same rig at a lower cost. The first way would be better though
Old 19-03-2007, 07:46 PM   #9 (permalink)
Yeh, I would prefer the first, but would you be kind enough to advise me on my conifiguration? As I say, I am a hardware newbie
Old 19-03-2007, 08:00 PM   #10 (permalink)
mod-the-pc's Avatar
Intel E6300 9400
Asus P5LD2-VM 4200
2x512MB DDR RAM 4200
Seagate 320GB SATA 4650
Sony 18x DVD Writer 2000
Casing 2000
Samsung 17" TFT 10600
Logitech cordless KM+Mouse 1700
Zebronics 7300 GS 256MB 3640
Total 42390
I'm not sure about the mobo & graphics card though. Maybe someone will shed some light on that
Old 19-03-2007, 08:05 PM   #11 (permalink)
assasin's Avatar
^^^ prices still too high
C2D E6300 8.2k
Asus P5N-E SLi 7.8k
2x512/1GB ddr2 4.2k
WD/Seagate 320GB 3.85k
the rest is ok.
this rig will cost u bout 45k.
assasin is offline
Old 19-03-2007, 08:31 PM   #12 (permalink)
mod-the-pc's Avatar
Chennai prices . Don't mistake me to be another crook like his vendor
Old 19-03-2007, 08:57 PM   #13 (permalink)
Well after looking through various sites, this is what I have come up with
Intel Core 2 Duo E6300 1.8 GHz Processor - Rs 9,150
Asus P5N-E SLi Mobo - Rs 7,800
1 GB RAM DDR2 - Rs 4,200
Seagate HD Sata 320 GB - Rs 4,100
XFX GF 7300GS 512MB PCI-E DDR2-Rs 4,100
15" TFT Monitor-Rs 9,000
This is coming out to be approx Rs 38,350
I am not sure about the prices, I live in Delhi, so prices might be higher. Is there any place where I can cut some prices? Also later on can I have another 7300GS gfx card to boost the performance?
Thanks
PS One thing I am wondering is, the E6300 is 1.8 GHz, isnt that supposed to be slow? Also, what exactly is a gaming mouse?
Old 19-03-2007, 09:18 PM   #14 (permalink)
You gave been GXified
gxsaurav's Avatar
why r u going with SLI? it will be very costly man. Out of your budget, skip SLI & get a normal motherboard (one PCIe X16 slot)
get 17" TFT, you will thank me later for this.
It's a 7300GS, stick with the 256 MB Model
about.me/gxsaurav
gxsaurav is offline
Old 19-03-2007, 09:24 PM   #15 (permalink)
So what do you suggest I should go with?
As you can see, Rs 7,800 which is pretty cheap for SLi
Old 19-03-2007, 09:29 PM   #16 (permalink)
assasin's Avatar
i suggested P5N-E SLi cuz it has very good OC features.also its a good mobo.if u can afford it then buy it.u wont regret it.u may also try Asus P5B.
price of the gfx card is a bit high.it sud be bout 3.3k-3.5k.
as far as price cut is concerned,bargain with ur dealer.
@mod-the-pc dood i didnt mean to suggest that ur trying to mislead him.at my place peices r lower.so i just mentioned it.i'm sorry if i hurt ur feelings.
assasin is offline
Old 19-03-2007, 09:46 PM   #17 (permalink)
Well I think I could afford to buy the P5N-E SLi if it is that good. Also, if I get the 17" tft + keyboard and mouse and dvd writer, with some bargaining, I could get it for around 42-43 K which is my original budget anyway?
@assasin, the prices you gave were from which area, as I saw the E6300 for 9200, and could also not get price for P5N-E Sli mobo, and the HD price was also higher than the one you gave. Also do you know where I could buy all this stuff in Delhi? Nehru Place? Once I do, how much will a computer guy charge to assemble all this?
Old 19-03-2007, 10:52 PM   #18 (permalink)
assasin's Avatar
the rates i gave u r from kolkata.
as far as assembling is concerned i think u'll be able to do it urself.if not the vendor from whom u'll buy ur stuff will take care of that.
assasin is offline
Old 19-03-2007, 11:01 PM   #19 (permalink)
I see, well there wont be much difference from Delhi rates? A couple of thousands I guess?
Old 19-03-2007, 11:12 PM   #20 (permalink)
mod-the-pc's Avatar
A quick question @hitman050. Don't you need speakers for your new PC? Do you already have one?
Old 19-03-2007, 11:21 PM   #21 (permalink)
I already have speakers with my old computer. They are Intex Subwoofer 880W, theyre not really that good, but still decent. I will be buying new speakers sometime next month though.
