hi i m not able to write cds on my drive ......all of them are failing by giving an error of power calibration ....this error has started coming from yesterday only...is it the problem with the drive...please help me in solving my problem.......thanks in advance
"The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila."
FEW OF SOLUTIONS ARE:-
Try another brand of media.
Update the firmware of your recorder.
Check your power connectors
Try different configurations(primary to secondary bus)
Clean or have your ROM DRIVE serviced
REPLACE ur ROM ...
Try writing at a lower speed like..........8x-16x and see. I had an Samsung CD-RW, it also had this same problem.
damn it
throw that fuc#### drive away
i too had samsung sw252f
it also gave me same power calibration error
i couldnt find a fix so i stopped burning from it
i got a liteon 5236v combo for 1100 bucks & it rocks
it burns flawlessly even at 52x get it now if you are a serious burner
Type Services.msc at Start->Run
Search for and double click on the IMAPI Cd burning COM Service. Change its startup type to Disabled.
Restart the computer and try writing again
__________________ Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB
Nokia N86 8MP
