Re: DVD Drive not reading CD DVDs.. plz help..
Open your Cabinet, unplug the drive cables, clean the connectors as well as the sockets with a soft brush. drive out the dust from the mobo. Reinsert all the cables and try.
__________
If not, then try using a Lens Cleaner.
Nokia N86 8MP
Reason: Automerged Doublepost
