Old 18-03-2007, 11:25 AM   #1 (permalink)
tango_cash's Avatar
Default is ddr2 ram supported by 915gav intel orignal mobo???
hi
i have a 2.8 gz intel proccesor(the hot one with hyperthreding and pinless design). and a intel orignal 915 gav mobo.
i have 256x2=512 mb ddr ram at 400 mhz.
i am planning to buy 1gb more ram. which is the best ddr ram.
and is ddr2 supported by my mobo.
tango_cash is offline
Old 18-03-2007, 11:39 AM   #2 (permalink)
assasin's Avatar
Default Re: is ddr2 ram supported by 915gav intel orignal mobo???
no ddr2 ram is not supported by ur mobo.
get a stick of 1gb ddr 400.
go for Transcend jet ram.
assasin is offline
Old 18-03-2007, 11:44 AM   #3 (permalink)
tango_cash's Avatar
ne idea ho much it costs
Old 18-03-2007, 11:46 AM   #4 (permalink)
assasin's Avatar
sud cost u bout 5k.
i myself use ZION ram sticks with Hynix chipset.they cost bout 4.2-4.4k.they r pretty good ram
assasin is offline
Old 18-03-2007, 06:08 PM   #5 (permalink)
shyamno's Avatar
Intel 915 doesn't support DDR II...
the best you can get out of ur current configuration is..to sell off the 2x256 MB DDR and get 2x512 MB DDR @400 Mhz..of Zion or transcend..
Zion 512 MB DDR @400Mhz ---->Rs.1800
Transecnd ---->around Rs. 2250 (Not sure)
shyamno is offline
