Old 17-03-2007, 06:51 PM   #1 (permalink)
nishant_nms's Avatar
Default Microphone problem in HD audio
I have a ASUS K8N-VM motherboard it fearures Analog Digital AD1986A High Definition audio. The problem is that the microphone doesn't works when I connect it to the rear port. But when I connect front pannel(AC'97 compliant) audio cable to the board then microphone works from front port but still it doesn't works from rear one. Help me thanx in advance.
nishant_nms is offline
Old 17-03-2007, 06:55 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Microphone problem in HD audio
May be your rear port is out of order. Microphone is not @ fault.
KDE on ArchLinux
The Unknown is offline
Old 17-03-2007, 07:10 PM   #3 (permalink)
but the rear ports gives sound when it is in 5.1 channel mode
Old 17-03-2007, 07:12 PM   #4 (permalink)
I meant the microphone port.
KDE on ArchLinux
Old 17-03-2007, 08:07 PM   #5 (permalink)
the microphone port works as the centre and subwoofer port in 5.1 channel and it makes sound
Old 17-03-2007, 08:21 PM   #6 (permalink)
You mean to say that your Mic, Speaker & Woofer is on the same port?
KDE on ArchLinux
Old 17-03-2007, 08:34 PM   #7 (permalink)
hey man the mic doesn't works in 2.1 mode and in 5.1 mode mic is not availabe. Haven't u used it ever(onboard 5.1)
Old 17-03-2007, 08:39 PM   #8 (permalink)
Buddy, i have an old pc. Not p4, its p3 here.
KDE on ArchLinux
Old 17-03-2007, 08:51 PM   #9 (permalink)
ok then
Somebody help me plz
Old 17-03-2007, 10:19 PM   #10 (permalink)
Web developer
narangz's Avatar
Lightbulb Re: Microphone problem in HD audio
try doing this:
go to master volume(speaker icon near clock)
click options and select advanced controls
under the mic slider click advanced. if it has an option 'front panel microphone' selected then de-select it.
narangz is offline
Old 18-03-2007, 08:39 PM   #11 (permalink)
@narangz thanx man it worked
repped u
__________
One more thing is Azilla HD compliant front panel connectors are available in market?
__________
any one using Azilla HD compliant front panels
__________
One more thing I also face a problem of noise in audio like when u recive no signal on TV. But when I uninstall the audio driver of Mobo and use default Microsoft driver it works fine. Any other pepole using ASUS K8N-VM face such problem or not. Plz post
__________
anybody there
__________
bump..
Old 19-03-2007, 10:12 AM   #12 (permalink)
repped u
__________
__________
__________
__________
anybody there
__________
bump..
Do u mean to say that hissing sound on the TV when there are ants running all over the TV?
KDE on ArchLinux
Old 19-03-2007, 04:31 PM   #13 (permalink)
Web developer
narangz's Avatar
Did you try installing latest audio drivers? Maybe it'll help. Also if you have any TV tuner card then update its driver & viewing application.
Well if you find Azilla HD compatible frontpanel do let me know
narangz is offline
Old 19-03-2007, 11:19 PM   #14 (permalink)
@The Unknown ya the same sound.
@narangz I have got latest drivers and I have no TV Tuner. I am not able to get tha Azaila compatible front pannel in my city so I was asking whether it is available in other cites or not
It works normal in Windows XP x64 Edition.
Old 22-03-2007, 10:08 AM   #15 (permalink)
bump
Old 22-03-2007, 04:49 PM   #16 (permalink)
NikhilVerma's Avatar
I have the exact same problem but weirder!
I have the same mobo ... K8N-VM ... with Analog Digital AD1986A High Definition audio but in Windows Vista it thinks that my card gives gives digital output ... But I want it to work the analog way ! As I don't hear any sound currently from it ...
But when I try to install my audio drivers for windows XP ... I get sound from only the front two speakers .... I have a 5.1 speaker setup.
Has anyone found drivers for this card for Vista ?
NikhilVerma is offline
Old 23-03-2007, 07:38 AM   #17 (permalink)
@ NikhilVerma do u face my problem in XP
Old 23-03-2007, 11:21 AM   #18 (permalink)
Your mic won't work in 2.1 mode either .... the .1 is for subwoofer... on which u connect ur microphone ... so to get microphone working on rear port set your audio to 4 channels and then try it.
Old 24-03-2007, 05:39 PM   #19 (permalink)
@NikhilVerma I have got my that problem solved.
I was asking about the buzzing/hushing sound
__________
You need the file AudioAD1986A6100-Vista.zip. It is in the download section (but not under our MB).
Old 27-03-2007, 01:08 PM   #20 (permalink)
even I get that hissing sound when I am playing a game and then I press Alt+Tab.... dunno how that comes
And can you plz gimme the direct link to the drivers for Vista ? I have analog speakers .... and I need 5.1 Audio in my vista installattion ...
Which download section you were talking about ?
Old 30-03-2007, 12:19 PM   #21 (permalink)
for vista x64 - http://dlsvr01.asus.com/pub/ASUS/mb/...6100_Vista.zip
for vista x32 - http://dlsvr01.asus.com/pub/ASUS/mb/...6100_Vista.zip
