Well I don't know exactly what speaker set I have, its about 3-4 years old, bought at the same time as
this monitor I have a problem with at the moment. Only one of my speakers works right now. No matter how much I adjust the contact of the plug, it doesn't work. So can this be fixed, or is it like my monitor in
this thread?
Would the Altec Lansing ATP3 be a good budget option? Since my monitor is not working as well and I will need to replace that, then would an LCD monitor with speakers in it be okay? I mean, the speaker quality should be decent for some music and a playing FIFA 07 (only one I like atm). Or are those speakers of pathetic quality? My monitor budget is 10k and my speakers is maximum 3k which I think is the cost of the ATP3.
