Old 16-03-2007, 03:39 PM   #1 (permalink)
Default 100% cpu while copying images folder
I often have to copy folders having large no. of images & I now have got a new comp, powerful enough yet when I copy a folder having 2000 images, it takes good amount of time & CPU utilization reamains 100%.
Is copying a cpu intensive job?
I tried on 2 desktops & 2 laptops they all showed the same behaviour, the total size of the folder was 202mb so not really a heavy folder.
On the other hand I made a 400mb file & copied that & that happens instantly without high cpu usage.
Is the no. of files causing this bottleneck or my XP needs somesetting so it can run faster?
ranjan2001 is offline
Old 16-03-2007, 05:30 PM   #2 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Default Re: 100% cpu while copying images folder
Hey Man Many Of The Hard Drives Support Content Not Mbs
So They Take More Time
You Can Download some ram increaser software
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 16-03-2007, 05:32 PM   #3 (permalink)
deadpulse's Avatar
No it does not utilize so much memory while copying just images. Then no matters how big your file is. There must be some process boosting on the background which makes your CPU utilization 100%. Check your utilization while no application is running. It should be 0% - 3% only. If it goes above this definitely there is something weird process hanging up.
"Attitude is not walking like a King, it's walking like I don't care who the King is......"
deadpulse is offline
Old 16-03-2007, 06:08 PM   #4 (permalink)
Some thing weird???
Thats why I checked up on different machines, but almost the same time & same 100% cpu.
this only happens when there are larger no. of images, seems that XP does some kind of monitoring of files & file names, which is slowing down the copying...........................but why 100% cpu????. I thought I am on a fast computer now.
THe only common thing which I used on all 4 comps is the cardreader & the CFcard, may be that is having a bottleneck, though its usb 2.0
__________
Update
I just did another test, copied a folder containing images from the card to the desktop 327mb containing 110 files.
It took 3.10 mins
I copied back the same to the card & now it took 6 mins , so it seems that the write /read speed of the card is creating issue, but this time the CPU was consumed3-4% only................strange
I then copied another 160mb folder containing 600 files & it took 6 mins, so it does seem that no. of filesdelay in someway, though the data is smaller amount being copied.
Old 16-03-2007, 06:20 PM   #5 (permalink)
The Unknown's Avatar
Originally Posted by ranjan2001
Some thing weird???
__________
Update
It took 3.10 mins
Here you are! You used USB for copying that's the reason for 100 % CPU. USB transfers require a heavy amount of CPU resources. That is why DSL providers don't recommend USB DSL modems and instead they use LAN.
__________
I am not sure about the second one, but probably; USB reading consumes a lot of CPU. Becoz. you have stated that.
KDE on ArchLinux
The Unknown is offline
Old 16-03-2007, 06:59 PM   #6 (permalink)
I tried formatting the card in the camera & then tried copying again & the CPU problem is solved, seems some issue with virus, though the AVG never reported any, nor did I see any suspicious looking files on card.
Old 16-03-2007, 07:07 PM   #7 (permalink)
Does AVG report virus?????? I knw that it is an antivirus. I was using AVG, but it never reported me a virus but @ the same time, avast reported me 20 viruses, 40 trojans and 2 adwares.
KDE on ArchLinux
