| Forum |
#1 (permalink) |
I have MTNL's Triband broadband connection with UTStarcom modem. Earlier I was using it with USB connection. Recently I have switched to LAN card. Thought there is increase in speed, I am facing constant break ups in connection. Almost every minute. It's really frustrating. I bought new Intex LAN card which I fixed in one of the two PCI slots. Earlier I had LAN card but there was some problem with it. What could be the reason? Is the slot faulty? Or is it driver problem? Any advice is life breather! |
#2 (permalink) |
and sometimes it runs without giving problems and sometimes it
create havoc just disconnecting now and then...isn't it.. Just give some rest to modem and try restarting with the software type: 192.168.1.1 hit enter admin and pass password ... restart from there..
Be like a postage stamp-stick to one thing until you get there. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
