| Forum |
#1 (permalink) |
but my vendor told that for that i have to upgrade everything from ram to ddr2 and hard disk to sata. also there is pircy issue that pirated software wont work on core 2 duo. and it will cost more than 18000 inc tax are all this true... [ so i decide d to buy pentium d (dural core). i wanted to know the performance difference between them and a sutable motherboard for it . i will use the machine for gaming an entertainment......... thanks |
#3 (permalink) |
Case Mod - 60% ||||||----
pentium D is a superheater.. best wen used to make toasts...
my pentium D runs at 55-58(idle) n bout 60-65(load).. if u can.. go for the low end core 2 duo... |
#7 (permalink) | |
CG Artist
#9 (permalink) | |
The real and only freedom is Public Domain. Everything else in unfree! Even those who claim to be the self styled evangelists of freedom are not free because freedom cannot be forced by any means! |
#10 (permalink) |
Back From Deathstar
Core2 duo 6600 is abt 16,000 but it begins from the 6300 which is a lot cheaper at abt 9-10k
.......Trust is a Weakness...... Guess what I am back after a long long long time |
#11 (permalink) |
The Frozen Nova
U can use ur old hdd with core 2 duo. C2D is a great choice.
I dream of a better tomorrow... where chickens can cross roads and not have their motives questioned. www.nerdweed.blogspot.com |
#16 (permalink) | |
#18 (permalink) |
^he needs some lesson
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#22 (permalink) | |
#23 (permalink) |
Nope... ^^The E6600 CPU itself is a little more than 15k
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
#24 (permalink) | |
#25 (permalink) |
Oho, I was talking about the minimum possible price.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
