Old 15-03-2007, 11:58 AM   #1 (permalink)
24online's Avatar
Exclamation CD Write Problem
he guys, I have CD writer of LG...when i insert disc...sometimes it shutdown my pc automatically... and sometimes in the middle of running cd, it hangs pc... so i have to restart pc from main switch... also when i write cd, it stops after burning.. and pc hangs...
so what I do to run CDs effectively in my CD rom ??/
**#(o)#**
24online is offline
Old 15-03-2007, 07:52 PM   #2 (permalink)
Default Re: CD Write Problem
Try cleaning ur drive using a lens cleaner
Also if ur on windows, check for viruses and malware/spyware. Try on another OS or on a fresh install of ur current OS.
Els mostly ur drive is conked, head to the service centre
Cheers
_______________________________________________
One World, One People!
sudhix is offline
Old 15-03-2007, 08:17 PM   #3 (permalink)
shashank4u's Avatar
Freshly install drivers and burning softwares...also try wat sudhix said.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 16-03-2007, 12:26 AM   #4 (permalink)
24online's Avatar
thanks. i will try.
**#(o)#**
24online is offline
Old 16-03-2007, 01:20 AM   #5 (permalink)
Try me
shantanu's Avatar
YOur PSU(SMPS) might be gone buddy!!! just try changing it , if oyu can get a friends then also it will be good...
After inserting a disc , the PC restarts or hangs just when adequate power is not provided to it,,,
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 16-03-2007, 10:21 AM   #6 (permalink)
assasin's Avatar
if the above methods fail then update ur drive's firmware.
assasin is offline
Old 16-03-2007, 05:34 PM   #7 (permalink)
deadpulse's Avatar
LG writers are pain in the arse so best option is not to buy them.
"Attitude is not walking like a King, it's walking like I don't care who the King is......"
deadpulse is offline
Old 16-03-2007, 06:01 PM   #8 (permalink)
shashank4u's Avatar
i m using one since last 3 years never faced any prob...
problematic are samsung writers Lg have a decent quality..
exceptions are always there..
