Old 14-03-2007, 01:11 PM   #1 (permalink)
Good Boy
george101's Avatar
Exclamation Core2duo and Motherboard???????
hi guys i want to update my pc with a core2duo processor and a new motherboard. Can u plz suggest a good combination within 12k and give its details. Also i have a doubt. i use a 160GB PATA HDD now. Is there a motherboard that supports botha PATA and SATA / SATA II so that i can upgrade my HDD later? Also plz suggest a good graphics card with 5k.
george101 is offline
Old 14-03-2007, 01:45 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Core2duo and Motherboard???????
You can buy
Processor - E4300 Rs7900
Mobo - Asus P5LD2-VM SE Rs.4100.
Graphic Card - XFX 7600GS 512MB Rs.5500.
Yes you can use PATA on that MOBO i think
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 15-03-2007, 12:32 PM   #3 (permalink)
Good Boy
george101's Avatar
Red face Re: Core2duo and Motherboard???????
thanks for your reply sukhdeepsinghkohli
__________
but can u plz verify that it supports both PATA and SATA so that i can use present hdd now and upgrade later
Old 15-03-2007, 01:00 PM   #4 (permalink)
assasin's Avatar
^^^ the mobo supports PATA,but afaik it supports only 2 PATA devices.so its better get a SATA II hdd.if u can increase ur budget,buy MSI P965 NeoF.its a far better performer and its based on 965 chipset.drawback is it doent hav onboard gfx.so u'll hav to spend bout 3k for a cheap gfx card (6200TC)
assasin is offline
Old 15-03-2007, 02:19 PM   #5 (permalink)
digiFriend's Avatar
Thumbs up Re: Core2duo and Motherboard???????
it is better to buy E6300 then E4300
price of core 2 Duo E6300 @1.86 Ghz is Rs 8900.
E4300 has no virtualization tech. and its FSB is 800 MHZ
while E6300 has virtualization tech. and FSB 1066 MHZ
you never know what you can do until you try
digiFriend is offline
Old 15-03-2007, 04:21 PM   #6 (permalink)
darklord's Avatar
So ??? whats the use of Virtualisation now ?
whats wrong with 800FSB ?
I would definately not pay 1k more for those 2 things.
4300 has a 9x multi compared to 7x of 6300.9x helps a lot while OC'ing though.
darklord is offline
Old 15-03-2007, 04:44 PM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
9x multiplier in 4300 would do no good if he plans to OC, the FSB can be a bottleneck if extensive OC is the need. Otherwise no difference between the two....
But for me.......C2D without OC is like egg without salt...
Virtulazation tech is not bad at all, however it entirly depends on ones use. Its like vmware but hardware assisted.With virtualization technology, you can turn one physical PC into several virtual systems, all running different applications and OSs. For example, theoretically you could run an FTP server on one, a Web server on another, have a database running on a third, and still be playing a game or surfing on the fourth.
sam9s is offline
Old 15-03-2007, 05:31 PM   #8 (permalink)
darklord's Avatar
9X multi wont help ???? :S
Take your case, you have ur 6300 @ 3GHz , 3000/7 = 428FSB
Where as with 4300, 3000/9 = 333 FSB
Same speed at lesser FSB.Not many boards clock high FSB.965P and 680i/650i based boards can do that.
Also mostly @ 350-360 FSB,the strap changes atleast happens with 975X.
I know what VT is,i never said its bad,but its definately not a feature thats a necessity.
darklord is offline
Old 16-03-2007, 03:31 PM   #9 (permalink)
Good Boy
george101's Avatar
i've decided to buy E6300. Which is the best mobo for c2d within 8k with onboard graphics and ddr2. i want mobo with onboard grapihics so that i can buy nvidia 8600 or the like when it is launched. shud i go for intel original or asus. plz help guys. i'm very confused
Old 16-03-2007, 03:46 PM   #10 (permalink)
Google Bot
Pathik's Avatar
if u r planning to buy a gfx card soon than get a mobo wit ocing capabilities rather than onboard gfx..
Pathik is offline
Old 16-03-2007, 04:02 PM   #11 (permalink)
Good Boy
george101's Avatar
but 8600 will be launched only on may i think and i'm getting pc this month
__________
well which is the best mobo for c2d within 8k with onboard graphics and ddr2 guys? plz reply soon
Old 16-03-2007, 06:17 PM   #12 (permalink)
Host4Cheap.org
Best MOBO according to me with onboard graphics is Intel DG965WH. I myself ordered it from USA back in Nov when it was not in India
Only Drawbacks
1. Not for someone who like to overclock
2. Very specific on RAM. 1.8v and 5-5-5 or 6-6-6 Timings.
Old 17-03-2007, 12:12 AM   #13 (permalink)
darklord's Avatar
Only Drawbacks
Dont you think that it depends on the RAM ? regarding timings and voltages ? I dont think that board would be picky with RAM.1.8V 5-5-5 is something any god damn RAM is capable of doing.Pretty standard JEDEC spec.
darklord is offline
Old 17-03-2007, 10:16 AM   #14 (permalink)
Host4Cheap.org
Check out this
http://www.intel.com/products/mother...ddr2/index.htm
There are tons of reviews i have read about the RAM Issue. There is even a post FS: Brand New Intel DG965WH m/b The Guy wants to sell because he got Corsair RAM from USA and it wont work on it
Old 17-03-2007, 10:47 AM   #15 (permalink)
darklord's Avatar
Check out this
Dude !!! that guy has specifically mentioned his intent to overclock the RAM ,which is why he is selling the board.I dont think that is remotely related to compatibility issue.Also most of the well known RAM Modules from reputed companies have atleast a single SPD entry that is exact same as JEDEC spec so that it works flawlessly on all motherboards not causing compatibility issues.
darklord is offline
Old 17-03-2007, 10:51 AM   #16 (permalink)
Host4Cheap.org
No Dude! PM him and ask. I couldnt find his post about the RAM issue. If you are still unsure about it, go to Google and search DG965WH reviews and see what you find
I dont have anything against the MOBO, heck! i ordered this from USA and i love my MOBO but i just want to aware the people
Old 17-03-2007, 10:56 AM   #17 (permalink)
deathvirus_me's Avatar
U could have found similar alternatives here ... even a MSI P965 Neo-F with a 7100GS would be better ...
deathvirus_me is offline
Old 18-03-2007, 11:45 PM   #18 (permalink)
moshel's Avatar
__________
u can go for a 945 based mobo will come arnd 5k and has onboard gfx too(not too sure).
moshel is offline
Old 19-03-2007, 12:32 AM   #19 (permalink)
premsharma's Avatar
Don't agree with you. If you ordered from USA does not mean it is the best. You like it be happy with it. GMA 3000 sucks. Even ATI X200 onboard D102 is better than GMA 3000
premsharma is offline
Old 19-03-2007, 01:07 AM   #20 (permalink)
Be aware that all these boards are ddr2. If you don't have ddr2 memory in ur current setup, you'd have to change ur ram too.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 19-03-2007, 01:14 AM   #21 (permalink)
assasin's Avatar
wats the cost of a Asus P5B Dlx and P5N-E SLi mobo.which one of these will be a better board for C2D E6300?also suggest any other good mobos.
assasin is offline
Old 19-03-2007, 01:28 AM   #22 (permalink)
premsharma's Avatar
Other board is MSI P965 Platinum and would be arround 9000 - 10000 by now.
Old 19-03-2007, 01:40 AM   #23 (permalink)
darklord's Avatar
I wouldnt compare these 2. one is a deluxe board and other one isnt.
Although i would take the P5N-E SLI for the 650i Chipset and the price.
P5B Dlx = 12-12.5k
P5N-E SLI = 7-7.5k
darklord is offline
Old 19-03-2007, 01:55 AM   #24 (permalink)
assasin's Avatar
all i want is a mobo with good oc abilities.onboard gfx is not necessary cuz i already hav a 6600 gfx card.so which mobo sud i buy?
assasin is offline
Old 19-03-2007, 12:37 PM   #25 (permalink)
darklord's Avatar
Asus P5N-E SLI makes sense.Performance wise 650i and 680i are same. Reason for that is the Northbridge in both is the SAME.Its the Southbridge that is different.680i uses NV 590 SLI as Southbridge to provide the additional PCIe lanes whereas 650i uses NV 430 as SB hence the lesser no. of PCIe lanes.
Asus has launched P5N32-E SLI Plus which is basically ditto similar to P5N32-E SLI looks wise and features wise BUT difference lies in chipset.Asus did something on their own,they clubbed 650i with NV 570 SLI to reduce costs yet offering similar OC platform.
Anyways coming back to the topic, Asus P5N-E SLI provides 1.6V+ Vcore and 2.5V+ Vdimm and ~ 1.8V VMCH. That board can crack 400FSB in a fraction of a second and can do 500 too but with better cooling.So OC wise,excellent board.It lacks the superior power circuitry of the Asus P5N32-E/Striker Extreme but still gets the job done.
BTW Striker Extreme and P5N32-E share the exact SAME PCB.
Just a few Caps n stuff here n there.
Heck even the PCB has Striker Extreme printed on it which is hidden by a BIG white sticker that says 'P5N32-E SLI'
darklord is offline
Old 19-03-2007, 01:07 PM   #26 (permalink)
assasin's Avatar
So i sud buy P5N-E?will it better than P5B,i.e Intel 965 based mobos in all respect?
assasin is offline
Old 19-03-2007, 05:39 PM   #27 (permalink)
The High 5 Flyer
sam9s's Avatar
mmmm point here, bad I missed that. The strap issues are with ASUS P5B as well. VT's significance entirly depends on ones use.
Its woud be good to see how well we can OC 4300 with P5B, if any one tries that.....
__________
P5N is not "better" than P5B, it is targeted to a different user who plans to use the SLI feature, plus the only difference is the FSB which is 1333 in P5N case. ( We dont even have CPUs supporting 1333 FSB). Except that there is no difference and point getting a P5N, and AFAIK P5B is less expensive than P5N-SLI (I'd suggest u check out). P5B does not in no way and in any department lack in OC features. Its an OC enthuastic delight. P5B can crack 400 FSB in a jiffie as well, can even reach 600 with a simple BIOS update. Supports Quad core and has all features which any other P5B 965 series has.
P5B rocks, me and ranjan can vouch for that.
A piece of advice:: Do'nt go for SLI its more of a hyped stuff rather than actual performance. Instead save the money and go for a single high ended graphics card.
sam9s is offline
Old 19-03-2007, 05:42 PM   #28 (permalink)
assasin's Avatar
^^^ thnx 4 the info dude.
assasin is offline
Old 19-03-2007, 05:52 PM   #29 (permalink)
darklord's Avatar
Hmmm...tricky question.Its upto you basically.Asus P5B is not a bad board at all,its very good.If you go for the Deluxe version, you get all the goodies associated with the regular Deluxe models from Asus.
If given a choice of P5N-E SLI Vs. P5B NON Deluxe, i would pick P5N-E SLI with eyes closed.
I would suggest,you compare both the P5N-E SLI and P5B Deluxe 1 on 1.See what all features you will be requiring and then decide.I personally feel the P5N-E SLI if a better or rather easier board for overclocking.Asus P5B Deluxe is known to have a non working or PITA 4:5 Divider.
Pls do not confuse him.IF you are talking of the Vanilla P5B,then yes it lacks in OC options.It has a mere 2.15V Vdimm. Whereas P5B Deluxe has 2.4V and P5N-E SLI has 2.5V
Err..nope.400 FSB,piece of cake...agreed.600,well nope.Just cos the BIOS has added support to bump FSB upto 600,does NOT mean it can do 600 FSB.Heck 500 FSB itself can be quite a job to achieve
thats not true.
Its not mandatory to use SLI,is it But if the board offers excellent OCability and VFM,why not go for it ? Heck i have had 4-5 different SLI boards till now,but i did SLI only once.
I still stand by my statement,
1] P5N-E SLI Vs. P5B Dlx = your call,depends on your priorities and budget
2] P5N-E SLI Vs. P5B Plain = P5N-E SLI hands down.
Hope this helps Assassin make his decision
darklord is offline
Old 19-03-2007, 06:20 PM   #30 (permalink)
assasin's Avatar
^^^ thnx 4 ur help.i think i'll go 4 P5N-E SLi,cuz P5B Dlx is beyond my budget at present.
as far as SLi set-up is concerned i'wont set-up SLi,never.
i think i'll do a few more rounds of googling and then decide.
anyway thnx to both of u for ur help.
assasin is offline
