Old 14-03-2007, 12:47 AM   #1 (permalink)
Alive Again...
satyamy's Avatar
Default Good PC needed..........?
I want to buy a New Intel PC
My Budget is around 25K
I need 3.2HT Processor + Intel Motherboard
512MB RAM, 160GB HDD, DVD-RW, Floppy Disk, 17" Flat Monitor (If possible Samsung), Very Good Looking Silver Colour Cabinet, Optical Mouse, Very Very Smooth Multimedia Keyboard & a Small, Simple & Smooth Speaker Just this much..................
Can i get this
or a better config in 25k
Waiting for Your Suggestion & Comments
Pls tell me if anyone have any idea about this
satyamy is offline
Old 14-03-2007, 12:56 AM   #2 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Default Re: Good PC needed..........?
Well, for 25k, Core 2 duo is out of question here. I would rather recomend going with AMD insted in 25k. Either stretch your budget or go with celeron cos Core 2 duo + DG965WH mother alone costs about 13k
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 14-03-2007, 07:26 AM   #3 (permalink)
Yes, I too recommend AMD over Intel... At lower range/mid range, if you choose AMD processor and motherboard, the savings you make can be used to purchase a decent graphics card. This will be especially useful if you are into gaming or multimedia processing... If you have to do only business work, you can skip the graphics card and go for a higher product compared to Intel at the same cost (cost includes processor+motherboard)
Arun
Arun
sakumar79 is offline
Old 14-03-2007, 09:15 AM   #4 (permalink)
18 Till I Die............
Do you ever learn satyamy? This isn't the first time you've made a post in wrong section.
http://www.bash.org/?258908
mehulved is offline
Old 14-03-2007, 11:10 AM   #5 (permalink)
Alive Again...
satyamy's Avatar
Cool Re: Good PC needed..........?
ok
thanks for moving the thread to right place
& My Name is "Satyam"
No one is getting me here
My Question is, can i get the Config i specified in 25K or not.......?
I dont want to go for AMD i only need Intel.......
So Pls help me...................
satyamy is offline
