Old 13-03-2007, 11:59 AM   #1 (permalink)
g_goyal2000's Avatar
Exclamation Hard Disk makes noise & whistles
Hi guys.
I recently got my Samsung 80 GB IDE/PATA (SP0802N) hard disk replaced. I was given a SP0822N instead of my old model no..
I've noticed something odd with this replacement hard disk.
When the computer powers up, while POST the hard disk makes a single click noise. It comes on every POST.
And when I shut off the computer, then also this single click noise comes. On every shutdown, this happens.
Also while normally working in Windows, sometimes a single click noise as well as a mild whistling noise also comes. Not frequently but sometimes.
This never occurred in my original hard disk (SP0802N) that I had bought.
I also have a Hitachi 40 GB & a Seagate 10 GB
hard disk and this thing doesn't happen in them.
Is this normal or a problem?
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 13-03-2007, 12:01 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Hard Disk makes noise & whistles
Do u mean some kinda light Whistling noise while the computer operates?
KDE on ArchLinux
The Unknown is offline
Old 13-03-2007, 12:20 PM   #3 (permalink)
MMO Addict
amitava82's Avatar
i have same HDD and i get single click sound while start and shut down. nothing else... do you get the click sound while working or after keeping PC idle for a long time? check you power option if "turn off HDD" is on, if it is then turn it off n let us know if you still get the sound..
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 13-03-2007, 01:23 PM   #4 (permalink)
Oh that click sound kya? I have that always because i have enabled BIOS to turn off my HDD after 1 min. of Idling.
KDE on ArchLinux
Old 13-03-2007, 01:57 PM   #5 (permalink)
MMO Addict
amitava82's Avatar
ya, i guess he too having same noise.. so check both BIOS and windows power option..
Old 13-03-2007, 02:30 PM   #6 (permalink)
i always keep BIOS HDD off coz. it gives the HDD some relief and increases its life. Also if the comp. hangs and theres noone near it, HDD will be running. Its a complete waste of energy and reduction of HDDs life. BIOS does not hang with Windows.
KDE on ArchLinux
Old 13-03-2007, 05:46 PM   #7 (permalink)
Yes, that's it. But it ain't frequent & happens rarely. But that is a problem. Isn't it?
Old 13-03-2007, 05:57 PM   #8 (permalink)
MMO Addict
amitava82's Avatar
most probably its the fan noise. take i peek inside the cabinet. believe me, my CPU makes noise like a jet engine
Old 13-03-2007, 06:02 PM   #9 (permalink)
Is your hard disk original one or a replacement? Does this sound come in everyone's hard disk on system startup & shutdown?
The "HDD SMART" setting in BIOS is disabled. I know this setting puts a lot of load on the HDD. Also, this setting doesn't help as it should.
Anyway, back to the topic.
"Turn off hard disks" & "System Standby" are both set to never.
I have enabled "System Hibernates".
So, the sounds (click, whistle) can't be due to these.
I get the sounds while I'm working.
I also get a click sound when I've logged on to Windows (after bootup process has finished).
Plz guys. Help.
My warranty is expiring this month end & I need complete info.
__________
Nope. Not the fan. Never had this noise with my other 2 hard disks or the original Samsung one.
Old 13-03-2007, 06:21 PM   #10 (permalink)
GOTO CPANEL(CLASSIC MODE)>POWER OPTIONS>CHECK WHETHER OPTION HDD OFF IS NEVER. See scrshot.
KDE on ArchLinux
Old 13-03-2007, 06:23 PM   #11 (permalink)
Checked. "Turn off hard disks" setting is set to Never.
Old 13-03-2007, 06:26 PM   #12 (permalink)
Did you thoroughly check it in the BIOS. Coz i have enabled it in BIOS so i have that click sound everytime.
KDE on ArchLinux
Old 13-03-2007, 07:00 PM   #13 (permalink)
My BIOS doesn't have this setting. Besides, I had been using my original HDD for close to 3 years & the mobo for 1.5 years with no sound from HDD. So, problem may be with this replacement HDD.
Old 13-03-2007, 07:06 PM   #14 (permalink)
May be buddy, & what's mobo? Consult your technician or goto the company or test it on ur frnds cmp.
KDE on ArchLinux
Old 13-03-2007, 07:28 PM   #15 (permalink)
MMO Addict
amitava82's Avatar
my HDD is replaced one, about 3 years back.. no problem since then. if you are worried then take your HDD to service center n tell them you have bad sector. they will replace it without checking..
Old 13-03-2007, 07:53 PM   #16 (permalink)
Without Checking? Buddy All Data will be lost because they format the whole HDD. Also there are no partitions on it. They delete them.
KDE on ArchLinux
Old 13-03-2007, 08:10 PM   #17 (permalink)
MMO Addict
amitava82's Avatar
ya they dint check my HDD. same case with my BenQ DVDRW. i got it replaced. at least u get a replacement. you can always backup the data in DVD. don't forget he has 2 more HDD
Old 13-03-2007, 08:12 PM   #18 (permalink)
My HDD once suffered a short curcuit problem. I gave it to Seagte, they deleted all partitions
KDE on ArchLinux
Old 14-03-2007, 01:17 PM   #19 (permalink)
Arrow Re: Hard Disk makes noise & whistles
Back to the topic guys, plz.
And "mobo" is short for motherboard. BTW, are u new here?
I think I'll check my HDD at my friend's comp.
Till then, keep posting u'r solutions/suggestions.
Old 14-03-2007, 01:21 PM   #20 (permalink)
i am not new here. many ppl use m/b instead of mobo. So i got
KDE on ArchLinux
Old 25-05-2008, 08:00 PM   #21 (permalink)
Very late to post a reply, but still I will.
The "whistling" hard disk was faulty.
Got it replaced with a brand new one.
