Old 12-03-2007, 11:19 PM   #1 (permalink)
archillies's Avatar
Default long beeps....booting prob!!!
I recently built a budget pc with s754 mobo....I used it for a month and changed the new cabinet.....for this I moved all the parts frm old to new one...... while moving the mobo and video card they were applied some stress/force (due to tight screws)...now after installing everythng I hear continuous long beeps with a gap of 2-3 seconds....is it a mobo issue?
I found in some article that its Dram error code but guess its mobo one......I replaced ram/graphics card/hdd to hear the same beep......experts here plz suggest me wot to do now apart frm replacing mobo as I cant replace it frm the site I bought?
thanks in advance
my rig
BIOSTAR NF325-A7 Socket 754 NVIDIA nForce3 250 ATX AMD Motherboard
AMD Athlon 64 3200+ Venice 2.2GHz 512KB L2 Cache Socket 754 Processor
3DFuzion 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) Desktop Memory
Maxtor 60GB HDD 5400 rpm
Creative Labs ATI Radeon 9600XT 256MB 600Mhz DDR AGP DVI
ARCTIC COOLING ALPINE64 92mm CPU Cooler
Ultra Wizard Black Mid Tower Case
archillies is offline
Old 12-03-2007, 11:23 PM   #2 (permalink)
The Unknown's Avatar
Default Re: long beeps....booting prob!!!
First Check All the parts in the box that whether they are connected properly or not. Mostly such problem occurs due to RAM. I also had this once when the RAM freqs. not matched and after replacing it, comp. started working.
KDE on ArchLinux
The Unknown is offline
Old 12-03-2007, 11:28 PM   #3 (permalink)
archillies's Avatar
No luck dude.....ram was new one too!!!
Old 12-03-2007, 11:29 PM   #4 (permalink)
^^ How many RAM chips have you inserted?
KDE on ArchLinux
Old 12-03-2007, 11:52 PM   #5 (permalink)
archillies's Avatar
just one see my rig
Old 13-03-2007, 05:20 PM   #6 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Try to remove your graphics card and use the onboard video bus to insert the monitor's address bus
Also check the graphic card and motherboard for bent pins, capacitors or transistors
techtronic is offline
Old 13-03-2007, 05:39 PM   #7 (permalink)
Originally Posted by archillies
just one see my rig
Ok, Does your m/b support DDR 400?
KDE on ArchLinux
Old 13-03-2007, 09:34 PM   #8 (permalink)
archillies's Avatar
@ techtronic......will replace it again and try my luck
@ The Unknown yes it supports ddr400
Old 13-03-2007, 09:56 PM   #9 (permalink)
I have this last solution for you. If it doesn't work, i am sorry that i can't help you with this problem. Try cleaning your box with a vaccum cleaner. Many a times this works for me when my comp. starts hanging. Good luck
KDE on ArchLinux
