Old 11-03-2007, 03:32 PM   #1 (permalink)
Default Having problem with PC
I am having AMD 3200+,ASUS SLI-deluxe mobo,512 mb ram, GF6600 LE ,200 GB WDC.The problem is when ever I watch movies the picture hangs for few seconds and continues.and some times i get a blue screen.I am having two ram modules one is 256 DDR 333 and the othe one is 256 DDR 400.what is the problem with my PC.
neoalies is offline
Old 11-03-2007, 03:48 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Having problem with PC
Causes:
Bad Ram- try cleaning it or replacing. also check on another comp.
Bad HDD- defrag, check for bad sects. also check on another comp.
BIOS Caching enabled- Disable BIOS caching.
KDE on ArchLinux
The Unknown is offline
Old 11-03-2007, 04:16 PM   #3 (permalink)
uchiha.sasuke's Avatar
this blue screen comes only when u watch u muvee or other times also???
True Power lies within the blood of your peoples revenge...The devils fruit can lead me there...
uchiha.sasuke is offline
Old 11-03-2007, 06:42 PM   #4 (permalink)
The blue screen comes any time
__________
It comes other times
__________
mostly I get this error message STOP message:0x0000009c and 0x00000007E
neoalies is offline
Old 11-03-2007, 06:50 PM   #5 (permalink)
@neoalies,
Is BIOS Caching enabled? If yes try disabling it. When i enable it, BSODs start appearing.
KDE on ArchLinux
Old 11-03-2007, 07:47 PM   #6 (permalink)
assasin's Avatar
take out ur gfx card,clean contact points and pci-e slot,do same with ram.
if prob persists after that,try a higher watt PSU.
assasin is offline
Old 11-03-2007, 09:08 PM   #7 (permalink)
Try running memtest to chk the ram. Available on linux install disc or the ultimate boot disc
_______________________________________________
One World, One People!
sudhix is offline
Old 11-03-2007, 09:52 PM   #8 (permalink)
dOm1naTOr's Avatar
Take out each of the ram modules and try running PC using 1 module at a time.
Also update: chipset, gcard, and sound drivers.
Also install latest autopatcher.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-03-2007, 10:12 PM   #9 (permalink)
http://support.microsoft.com/kb/162363
http://support.microsoft.com/kb/330182/
These r the links ............where u will find ur solution......
