Old 11-03-2007, 09:44 AM   #1 (permalink)
56561's Avatar
Unhappy Optical Drive Blast. Pc Not Running . Please Help
Last night suddenly an explosion occured inside my pc and it turned off . i had LiteOn DVD writer . i understood that something occured inside it . when I turned it on the PC LEDs turned on but nothing loaded , i opened the optical drive...yes the dvd turned into 1000 s of fragments .
what should i do now? well I want to know do i need to change the optical drive or it can be curable?
and is my HDD, ram also affcted ?if only optical drive went out then others should work?????
can anyone tell me some good places where I can take my PC for a low cost cure? I stay in navi-mumbai area .
reply please........
56561 is offline
Old 11-03-2007, 11:07 AM   #2 (permalink)
Gaurav's Avatar
Default Re: Optical Drive Blast. Pc Not Running . Please Help
afaik there nothing wrong done to your comp, remove the dvd drive., and it should work fine.
Gaurav is offline
Old 11-03-2007, 04:14 PM   #3 (permalink)
The Unknown's Avatar
Nothing shud hv happened to the computer's internal parts but the DVD Writer is NOT CURABLE Same thing once happened to me. CD blasted. But nuthin happened to the computer.
KDE on ArchLinux
The Unknown is offline
Old 11-03-2007, 06:48 PM   #4 (permalink)
Thats scary!!!!!!!!!!
Never heard of any such thing, why would that happen?
Did the liteon did not like ur DVD, was it too hot to handle?
ranjan2001 is offline
Old 11-03-2007, 06:51 PM   #5 (permalink)
I gave the CDROM to my engineer, he said it is NOT REPAIRABLE
KDE on ArchLinux
Old 11-03-2007, 07:12 PM   #6 (permalink)
yes.....im sorry but in such a situation.....u must replace the drive......but before u do that......
disconnect the drive and try starting the comp...
all the best
ronweasley is offline
Old 11-03-2007, 08:23 PM   #7 (permalink)
nishant_nms's Avatar
always use good quality media
nishant_nms is offline
Old 11-03-2007, 08:52 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
Talking Re: Optical Drive Blast. Pc Not Running . Please Help
thats really scary
how is it possible that a DVD or CD breaks inside the drive???
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 11-03-2007, 09:06 PM   #9 (permalink)
prasad_den's Avatar
^^ Ya. I too don't understand, but it has happened to one of my friends..
Can anyone throw some light on when and why it happens, so that we can be careful..??
prasad_den is offline
Old 11-03-2007, 09:47 PM   #10 (permalink)
dOm1naTOr's Avatar
Yaar.. this happened 2 or 3 times for me too.
Three of my CDs has broken with huge sound inside my BenQ CD writer.
U shud immediately pull the plug[ yes dun wait for shut down- pull it]
What I did was to open the cover of the drive and carefully cleaned the particles with a small painting brush. Clean the eye of the drive with a soft earbud dippen in ALCOHOL[ not the 120%]. My drive has survived 3 such blasts and is perfectly workin now.
I dun think its due to low quality disc. The discs that were broken were: a sony, an LG and a local one. But all were very old discs.
Use older discs with care. Dun even think about using a disc which has started cracks from the centre hole to out. The disc will become useless if crach touches recording layer. But its risk to put the CD on drive.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-03-2007, 09:56 PM   #11 (permalink)
Really scary!!!!!
have any of u tried purposely breaking a CD, it takes a good amount of force to do so, due to its plasticity.
Need to be quite careful using older CDs
Old 11-03-2007, 10:06 PM   #12 (permalink)
@s18000rpm, prasad_den, ranjan2001
Actually, these cd blasts often happen with low-quality cds and hot reders/writers. I mean that most cd's blast in the drive either due to low qulaity or if the cd has been inside the drive for a long time spinning, i gets heated and blasts.
That is what happened with my Win 98 CD. But i had a spare copy of it. Now i use xp. So i take out that CD very rarely. When my CD blasted, the heat remained for atleast 5 mins. You can imagine that how hot i must have been. And the cd was of Sony. Usually nothing happenes to the computer when CD blasts. My computer was running when it blasted & even after blasting, my computer was still active!
KDE on ArchLinux
Old 11-03-2007, 10:41 PM   #13 (permalink)
dOm1naTOr's Avatar
I said " pull out the plug" immediately after the blast to avoid any damage to the eye. The drive wud probably try to read from the disc even if it has blasted, and the eye may get damaged due to some sharp edges. Sometimes the eye wud have gone at the time of blast itself.
But there is more probablity to save ur drive if u pull of the plug and start PC with the drive only after a thorough cleaning.
During the first start after the cleaning, see if there is any noise from drive. Load some irrevelent disc to see if it worx.
G3: XPS M1530 |
FZ 16.
Old 11-03-2007, 10:59 PM   #14 (permalink)
Still Shining!
Lucky_star's Avatar
One of my CDs broke into 2 when I was copying something from it at full speed. I found that it happened when the CD became very very hot like a frying pan inside the drive. Moreover there were center cracks in it that made it break easily..
Nokia N86 8MP
Lucky_star is offline
Old 11-03-2007, 11:12 PM   #15 (permalink)
dOm1naTOr's Avatar
If nyone wants to break CDs in their drive, use s/w Nero Drive speed. In this u can manually make ur drive read a disc at max possible speed. Durin that time the drive is workin fully nd Cds become hot quickly. And also the disc is spinning at max speed. At this time any weakness on disc or some imbalance during rotation cud blast the disc nd of course heat cud also bleast it.
G3: XPS M1530 |
FZ 16.
Old 11-03-2007, 11:14 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i also have expreinced it..soem 1-2 years back....when i was wacthing a movie from a CD..it blasted....i was also not able to eject...adn that time i thought i am screwed.....
Then removed the drive...took it to nearby computer repair wala..he opened it, used soem blower to clean it....took abt 10 minutes and gave me back...he said i was lucky that nothing had happened to cd rom....but he said to check if it burns properly there after...lucky me ...the drive served me well 1 year after that incident...and then came DVD writer..
wizrulz is offline
Old 12-03-2007, 01:38 AM   #17 (permalink)
ApoorvKhatreja's Avatar
Yeah...It happened with me too. My engineer told me it was due to CD imbalance and adviced me not to use old and cracked CDs.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 12-03-2007, 01:09 PM   #18 (permalink)
EYE? WHose eye. Ours or the drive's eye(lens)?
KDE on ArchLinux
Old 12-03-2007, 02:33 PM   #19 (permalink)
dOm1naTOr's Avatar
The lens of optical drives nd player are termed as 'eye': technically speaking.
G3: XPS M1530 |
FZ 16.
Old 12-03-2007, 05:07 PM   #20 (permalink)
^^ Ok. Thanks.
KDE on ArchLinux
Old 22-03-2007, 08:34 AM   #21 (permalink)
56561's Avatar
well, I have removed the dvd drive, now also the PC is not starting . when I am trying to start it , the lights r up ( i have zebronics antibiotic cabinet thats why I see all the leds r working) but nothing on screen ( monitor is ok).
what should i do?
-56561
56561 is offline
