Old 11-03-2007, 08:44 AM   #1 (permalink)
~ Harsh ~
hdsk.23's Avatar
Question Perx RAM
i have purchased the Perx Ram 512Mb single Slot 6 months back, at that time i havent seen on the ram that it is written matrix on it as that vendor give me that ram in the perx cover.
Can anybody is having Perx RAM ? I want to know that what is written on it whether it is Perx or something else...........
Please help me to sort out this problem how i will came to know that it is original Perx RAM or NOT!!!!!!!!!!
hdsk.23 is offline
Old 11-03-2007, 09:15 AM   #2 (permalink)
~ Harsh ~
hdsk.23's Avatar
Question Perx Ram website
does anyone know the Website of PERX Company makes computer RAM's
hdsk.23 is offline
Old 11-03-2007, 10:07 AM   #3 (permalink)
assasin's Avatar
Default Re: Perx RAM
Every ram has the manufacturing company's hologram on 1 of the RAM chips.wat does ur ram hav?
assasin is offline
Old 11-03-2007, 10:21 AM   #4 (permalink)
dOm1naTOr's Avatar
U can also check out the manufacturer of memory chipsin ur module. Its written on each memory module in tiny fonts.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-03-2007, 04:51 PM   #5 (permalink)
~ Harsh ~
hdsk.23's Avatar
there is no hologram on it and matrix is written on every module of ram with tiny fonts........
i think it is not of perx am i right please help me!!!!!!!!!
hdsk.23 is offline
Old 11-03-2007, 05:35 PM   #6 (permalink)
nishant_nms's Avatar
perx doesn't makes RAM of itself. so ur RAM has matrix written over it
nishant_nms is offline
Old 11-03-2007, 07:42 PM   #7 (permalink)
assasin's Avatar
u sud always buy ram from reputed companies or having chipsets from reputed manufacturers.never heard about matrix and afaik PERX only sells cabinets,spkrs,PSU.
assasin is offline
Old 11-03-2007, 08:20 PM   #8 (permalink)
it is crap company
Old 12-03-2007, 10:17 AM   #9 (permalink)
What makes it Difference now if it's from Perx or else. If you have no problem with RAM just keep it use with full load, as it's just 6 month old - you may have 1yr Warranty - if crush or fail while Extreme use - replaced it.
Stick is offline
