Old 11-03-2007, 12:47 AM   #1 (permalink)
NP : Crysis
xbonez's Avatar
Default gaming mouse
Could neone plz tell me about any gaming mouse and its market price. i live in new delhi so availability shouldn't be a prob. also plz try to give link to website if u have it
xbonez is offline
Old 11-03-2007, 01:04 AM   #2 (permalink)
Default Re: gaming mouse
got to logitech.com or rptechindia.com(http://www.rptechindia.com/rashib2c/...ce&maincatgrp=)
saurabh DH is offline
Old 11-03-2007, 10:43 AM   #3 (permalink)
dOm1naTOr's Avatar
There are many options out there.
First I begin from the cheapest ones.
For 450~500 bucks: Tech com, Intex lasers
1600 DPI. Normal 3 buttons.
http://techcomindia.com/index.asp
For 800~1000
Genius laser mice: www.geniusnet.com
Iball laser mice : www.iball.co.in
For 1000 to 2000
Microsoft entry level laser mice
For 2000 to 3000
Logitech: MX 518 [2.5k]
1600 dpi laser
www.logitech.com
Microsoft Laser 6000
2000 dpi laser[ 2.6k]
For 3000-5000
Logitech G5 2000 Dpi [3.4k]
adjustable weights
Razer Diamondback or Copperhead[ 3.5k to 4k]
Best known laser in the world. Approved by FATAL1TY
Logitech G7 [5k]
Its the G5 wireless edition, but dun have weight adjustments, instead it has the Li-ion battery.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-03-2007, 03:07 PM   #4 (permalink)
aquamatrix's Avatar
well if you can get the MX 518, its prolly the best non laser gaming mice.
Razer is awesome, but ppl face loads of problems with it.
if on a tight budget go for i ball laser precise for 700 bucks.
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 11-03-2007, 04:10 PM   #5 (permalink)
The Unknown's Avatar
Microsoft Gaming RAT Rs.1000
KDE on ArchLinux
The Unknown is offline
Old 14-03-2007, 03:38 AM   #6 (permalink)
dOm1naTOr's Avatar
@aquamatrix
MX 518 is a LASER mouse, but uses Laser Engine 1 technology with 1600 dpi, whereas G5 has LASER Engine 2 tech with 2000dpi.
Its better to stretch 1k more to get the G5 itself. Its got lot more features,perfomance and comfort.
G5's feet are best and it has weight adjustment and its software support is superb[ but only work well in Xp, nut even in 2000].
Im currently using the iball one and its really gud for the price. Good controll of the crosshair and comfortable on hands too.Go for it if u are low on budget.
G3: XPS M1530 |
FZ 16.
Old 14-03-2007, 05:07 AM   #7 (permalink)
aquamatrix's Avatar
^^ i'm pretty sure MX 518 is optical.
well most gamers have there own views, some of the best professional gamers are still on 400 dpi optical mouses( the intelli series from microsoft being an example), while some are on 2000 dpi monsters.
if you take my opinion then mx518 + a good cloth pad is unbeatable.
Old 14-03-2007, 06:15 PM   #8 (permalink)
dOm1naTOr's Avatar
Even if its called an 'optical mouse', it uses laser engine 1 technology from logitech. So technically speaking its a laser mouse. Also the mouse seems to be very large, so some may not find it very comfortable. But due to the desing of G5, even people with smaller palms too can use it comfortably.
And u mentioned bout problems in Razer mice, but there are more s/w problems than for logitech than of razer.
G3: XPS M1530 |
FZ 16.
Old 14-03-2007, 09:14 PM   #9 (permalink)
aquamatrix's Avatar
well on grounds of technicality, i have no idea
but mx 518 is always graded under optical mices.
Old 14-03-2007, 09:53 PM   #10 (permalink)
dOm1naTOr's Avatar
Ive used MX 518, G5, MS laser 6000 etc and also had chance to use some best mousepads like razer mantis[on a friend's place: a distant friend so cudn't ask him to get one].
I personally liked the G5 one. As for me, i dun like to spend 3.5k for a mouse[even if its worth it], so went for iball for 750 bucks.
G3: XPS M1530 |
FZ 16.
Old 15-03-2007, 02:07 AM   #11 (permalink)
aquamatrix's Avatar
i've used iball too, and its too good for playing games like UT, Quake 3.
but for games that require low sensitivity gameplay like CS its definitely isn't good.
Old 15-03-2007, 03:14 AM   #12 (permalink)
MX518/DeathAdder/DiamondBack are all optical. Copperhead/G5/Habu/MS Laser are laser mice. Its pretty easy to see what sensor it is... just turn the mouse upside down . Also IMHO the Mantis is a POS. Laser performs well only on the right surface. On cheapo surfaces, it sucks.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 23-03-2007, 01:35 PM   #13 (permalink)
NP : Crysis
xbonez's Avatar
i'll get the iball precise mouse. how many buttons does it have?
xbonez is offline
Old 24-03-2007, 01:15 AM   #14 (permalink)
aquamatrix's Avatar
^^ ... a much better option is to get the microsoft intellimouse 1.1, it comes for 1.1k and is 5 button gaming mouse.
dont go for iball
Old 25-06-2007, 08:33 PM   #15 (permalink)
a razer copperhead and a mantis control..u can chek the pics on the official razer site- razerzone.com ...
axe0911 is offline
Old 25-06-2007, 09:03 PM   #16 (permalink)
Stalker's Avatar
^^that combo is awesome.....is it available in india??
Stalker is offline
Old 25-06-2007, 10:34 PM   #17 (permalink)
i have that combo..i noe that its damn gud...yes it is available in india go to the site and chek...
axe0911 is offline
Old 25-06-2007, 10:50 PM   #18 (permalink)
Stalker's Avatar
kool thx....how much did u buy it for??
Stalker is offline
Old 26-06-2007, 02:13 AM   #19 (permalink)
NP : Crysis
xbonez's Avatar
how much is the mx518 available for?
also, i saw a creative fata1ity gaming mouse? howz its rep? anyone used it?
xbonez is offline
Old 26-06-2007, 08:43 AM   #20 (permalink)
Stalker's Avatar
Fata1ity laser mouse.....looks different..
http://www.creative.com/products/pro...&product=15037
Fata1ity keyboard
http://www.creative.com/products/pro...&product=15332
Stalker is offline
Old 26-06-2007, 12:55 PM   #21 (permalink)
i think logitech g5 n intelli 1.1 are the best gaming mouses.specially intelli 1.1
is also a bit cheaper.bt u ll need a good gaming pad too.
BULLZI is offline
Old 26-06-2007, 05:11 PM   #22 (permalink)
dOm1naTOr's Avatar
u can buy razer mice and gud mousepads in india here;
http://www.therespawn.com/oscart/
G3: XPS M1530 |
FZ 16.
Old 26-06-2007, 06:02 PM   #23 (permalink)
yup i bot my mouse(intelli 1.1) n mousepad(qck+ steelseries) from there.
BULLZI is offline
Old 27-06-2007, 02:02 AM   #24 (permalink)
NP : Crysis
xbonez's Avatar
cost of mx518? and cost of creative fata1ity street price plz?
xbonez is offline
Old 28-06-2007, 01:29 AM   #25 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
I got Genius Navigator 535 Laser Gaming Mouse. Its 2000dpi, has the usual left button, right button , scroll wheel doubling up as middle button, 2 buttons on each side of the mouse. thats totally 7 buttons. Also below the scroll wheel , there are 3 buttons for 2000dpi, 1600dpi and 800dpi instant sensitivity switching. There is a not so obvious button under genius logo for changing gaming profile. This button allows you to select from 5 different mouse configurations stored on the mouse itself. Mouse configurations can be set by the agama software provided. The mouse can be used with all its features without drivers. The agama sofware (driver) is needed only for setting the profiles and once set it you can take it to LAN parties without the driver CD.
I bought it in Hyderabad for Rs 2360 inclusive of taxes with 3 years warranty from authorised dealer.
Techtree review
Only bad thing is that its lift off distance is high and needs getting used to.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 28-06-2007, 05:38 PM   #26 (permalink)
Now avoid Razers.. Lotta problems xcept fer the Deathadder variant..
MX518 is d best... Priced @ 1500 + taxes frm Rashi... Chek 'em out...
Avoid m'soft mouses coz they price high fer a lesser dpi...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 28-06-2007, 06:44 PM   #27 (permalink)
Stalker's Avatar
^^ will it require any special mousepad / surface?
& wat about M'soft Habu?? Digit had given it the zer01 award last year rite?? is it worth the 3k bucks or is razer better?
Stalker is offline
Old 28-06-2007, 07:45 PM   #28 (permalink)
dOm1naTOr's Avatar
@Stalker
Habu is actually designed by razer and its nor purely MS product. Its perfomance is similar to copperhead, and costwise only some 500 bucks cheaper than razer's.
G3: XPS M1530 |
FZ 16.
Old 28-06-2007, 08:12 PM   #29 (permalink)
Stalker's Avatar
^^thats rite....laser engine from razer & ergo design from MS......but isn't it good? U guys haven't considered it in this thread....
Stalker is offline
Old 28-06-2007, 09:09 PM   #30 (permalink)
dOm1naTOr's Avatar
Habu has somewhat cheap and low quality looks[ especially from underside]. The main diff b/w Habu nd Copperhead is the res changer buttons. In habu, it is located infront of the scroll wheel but in copperhead, its inside the side rubber rails.
The habu style is more comfortable as of reviews. Also as Habu is an MS one, we can easily buy in India and also claim warranty.
G3: XPS M1530 |
FZ 16.
