10-03-2007, 10:38 PM
Urgent Hardware & Chassis
Hi i am new at this so....
I am getting a new system, and having trouble getting the right kind of cabinet & Psu for it ,kindly lend me your wisdom and exp.
specifications:
Pentium D 2.8 (2*1 Mb)
Intel DG965WH
Kingston DDR2 1Gb (667MHz)
XFX 7600 GT
Seagate SATA 250 Gb (Barracuda)
Sony 18X D Layer RW
Cooler master Elite 330 or Centurion 534
1) PSU is the main thing here, should i go for Cooler master 380W or higher (i will get a C2D in 7 to 8 months ,all the rest will remain same except RAM)
2)I also want to ask about Zebronics PSU 500W-platinum(Rs 2200/-),how does it compare to coolermaster, quality wise.
3)Can i install a zeb-500w Psu in coolermaster centurion/Elite model Chassis.
Zebronics Peace VS Geforce2 ?? [Price range Chassis+PSU=4500/-]
I want to get this system ASAP
10-03-2007, 10:52 PM
Re: Urgent Hardware & Chassis
380 will do fine as for now but the moment u add more HDD & other additional cards & peripherals or upgrade to C2D then only u will needs more than 400 watts.
I bought zebronics 500w platinum along with Peace case.
XFX minimum required is 350watt & it has dual port soif u ever use 2 monitors then u will be short of the power.
If you play games & are sure that u will upgrade then either go for cheaper 400 watt as of now & while upgrading in future buy the 500 watt psu then, the rates will come down or for same money u will get better one by then.
10-03-2007, 11:09 PM
hey ranjan r u sure its 350w , see the box as i saw 400 watt on 7300GT and 500 on 8800GTX
10-03-2007, 11:21 PM
Since u asked , I just checked on my XFX box its mentioned as 350watt as minimum, this was bought on 20 jan 07.
I got 400watt zebronics earlier but later bought the 500w platinum.
10-03-2007, 11:38 PM
hi, first thanks for the quick replies, the XFX box says 350w, can i fit zeb 500w to a coolermaster cabinet.
10-03-2007, 11:46 PM
Ur welcome,
I guess so bcoz the psu sizes are common, just remember that this PSU has a top fan so in cabinets where there is no top vent u have to mount it ulta as I have done in peace.
R coolermaster cases available in delhi? if so where?
10-03-2007, 11:49 PM
yeah cooler master are available at delhi at
aditi computers
011-25591777
10-03-2007, 11:57 PM
coolermaster Products are available at
SMC International
B-10 & B11, Meghdoot Building,94 Nehru Place. new Delhi
011-26293001/2,011-26220546
