Old 10-03-2007, 11:26 AM   #1 (permalink)
Default computer not starting
i am having Asrock P4i45GV
fisrtly the computer suddenly closed.
then I again started it and after 2 mins it again closed.
I tried to check the bios & once entered into bios then agn it is closed.
now it is not getting started.. now even the bios is also not coming and the moniter is also not waking up.
plz help me i am in utter trouble, i have to work on my project...............
keep it cool
nd4spd is offline
Old 10-03-2007, 11:28 AM   #2 (permalink)
The Unknown's Avatar
Default Re: computer not starting
SMPS or PSU problem. try changing your PSU or SMPS.
KDE on ArchLinux
The Unknown is offline
Old 10-03-2007, 12:03 PM   #3 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Lightbulb Re: computer not starting
Try to cleaning up your RAM module and the slot may it will work or just clean up your SMPS.......
pritzdj is offline
Old 10-03-2007, 12:07 PM   #4 (permalink)
he says monitor itself is not starting. how cud it be RAM prob?
KDE on ArchLinux
Old 10-03-2007, 12:07 PM   #5 (permalink)
Cool G5's Avatar
Post Re: computer not starting
This seems to be a psu problem.Check with another psu.Also clean the ram & all other addon cards like gfx card,processor etc.
Cool G5 is offline
Old 11-03-2007, 07:01 PM   #6 (permalink)
chk ur processor/fan assembly....then chk ur psu 4 overheating...
(this thing happened to me too. found that the CPU fan had STOPPED. anyway it was a slot1 p3 processor......)
ronweasley is offline
Old 11-03-2007, 07:13 PM   #7 (permalink)
shashank4u's Avatar
hey do these things:
check up yr RAM
check out yr PSU(it may be the main prob)
and is there any sounds coming...
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 11-03-2007, 07:44 PM   #8 (permalink)
assasin's Avatar
try with a higher wattage psu and disassamble ur pc,clean it and reassamble it.
assasin is offline
Old 11-03-2007, 07:47 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
its 90% RAM problem
just take out the RAM & clean its contacts (with a pencil rubber) & then insert it in its slot.
its time to change your RAM Nd4spd dude.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 11-03-2007, 07:48 PM   #10 (permalink)
Google Bot
Pathik's Avatar
check ur ram... remove it and clean it...
also check ur su connections..
Pathik is offline
