I am not able to hear audio - ( Mercury Tv Tuner Card ) but i can view the video,
I have re-install the Tv Tuner driver
{ TV Capture Card WDM Tv Tuner &
TV Capture Card WDM Video Captuer }, Window Audio Driver ( Avance AC'97 Audio )
still i am not able to hear audio.
I had install 3 part software [ ChrisTV, Nero Media Home ] still no good.
Help is need!
first thing first: did you check audio cable that connects TV tuner output to Line In of your motherboard. make sure its not muted. my friend had same problem. you can also check by connecting your speakers directly to your Tuner Line Out port.
Mercury Tv Tuner Card is an internal one. I think my motherboard has built -in sound chip. so is there is any cable to connect TV tuner output to Line In.
saw ur card's pic and i think the green jack present on ur card is for line-out.so connect one end of the audio cable to this green jack and another end to the line in of u r mobo.this sud solve ur prob.
