Old 09-03-2007, 05:18 PM   #1 (permalink)
Cool Best Model Of Liteon
IS LITEON SOHW1693S THE BEST ONE?
I want the best one inside Rs. 2000. Which is the best?
XtremeFuturistic is offline
Old 09-03-2007, 05:34 PM   #2 (permalink)
shashank4u's Avatar
Default Re: Best Model Of Liteon
I think the latest 20x model from liteon is the best..
search in the forum and go for it..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 09-03-2007, 06:18 PM   #3 (permalink)
I WUD HAVE GONE FOR IT but techtree review says -
DVD-R Write speed not upto the mark.
what is -R,
what's +R, -RW, + .... etc. all specifications like these ?
Old 10-03-2007, 12:07 AM   #4 (permalink)
shashank4u's Avatar
hey plz search in the forum all questions have been answered before..
Old 10-03-2007, 02:12 PM   #5 (permalink)
Wow, I Cud Not Find Anything Here DUDE
Old 12-03-2007, 11:51 PM   #6 (permalink)
The Transcendental
The opinion of guys @ Techtree should not be taken at face value.
If you check sites like cdfreaks and CDRlabs, you'll know that all Liteons have some issues during the lead-in part of the burn with standard DVD-Rs, i.e. the liteon burners tend to be 'picky'.
On the other hand, DVD+R write quality tends to be quoted as better.
This may or may not matter.
I personally have a good experience even with DVD-Rs.
It might be due to the fact that DVD-R media especially the cheapos which have questionable quality tend to abound in the markets, as well as duplicates of original DVD-Rs. the same is not the case with DVD+Rs however. They are relatively scanty in India and pricier.
If you are of the adventurous kind, just buy a well documented burner
like the SOHW1693S and make your own write strategies for the media you use by flashmodding the burner. That way you get good quality burns even on cheap disks. This works out to be easier with Liteon burners than other brands due to good community support, i.e. the 'hackability' of Liteons is best.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
