Old 09-03-2007, 12:59 PM   #1 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
Default lcd monitor with svideo/composite inputs for tatasky help??
hi all digit forum members
i have been reading your forum for over a year now
your discussions are damn interesting & informing as well
this is my first post hope somebody responds sensibly thanx in advance
I need a lcd-tft monitor to connect directly to tata sky set top box ie I need a monitor which does have s video /composite / component inputs along with regular dvi/rgb inputs
i dont want to use my pc ac tv because i dont like to turn pc on 10 times a day
Im having a Samsung sync master940bw but it does have only dvi-d&rgb inputs
So ineed a new monitor with s video /composite / component inputs which i would be using as a lcd tv pairing it with my altec lansing mx5021 speakers
my requirement is for a monitor within 20-30k range 20"-22" in size for my room because no i repeat no lcd tv in indian market within 20-30k range
supports 1600*1200 resolution plus bass as compared to my altec lansing mx5021 this would be certainly awesome
according to my research i found some lcd monitors in indian market with s video /composite inputs they are
DellTM 2007WFP 20" UltraSharpTM Wide Screen Flat Panel LCD Monitor 28k
DellTM 2007FP 20" UltraSharpTM Flat Panel LCD Monitor 25k
DellTM 2407WFP 24" UltraSharpTM Wide Screen Flat Panel LCD Monitor 39k (so its not within my budget)
BenQ FP241W 24" hd compatible (but im sure its tag kicks a** )
asus PW201 20" wide screen (but i dont know its tag )
is there any other monitor in indian market aka nehru place with s video /composite inputs 20"-22" in size 20-30k range
from samsung /lg/sony/viewsonic or any other damn great brand?????
plez respond with price tag in nehru place and among them which would be a worth buy???
second option
is there any converter/splitter available which can convert composite video signal from tatasky set top box to vga (db-15) signal which i can use
with my Samsung sync master940bw standalone (man not via that damn pc tv tuner card it suc** a *****es son a**)
as of my googling i found some abroad but is there any available in delhi & what about converted signal quality is it of wow???
anyway respond man
luv thanx in advance
athlon 3000+ atop a gigabyte geforce 6150/nForce430 with hdtv out connected to fd55ve lg29" crt tv 576i @60hz& vga out connected to 19" sync master940bw 1gb kingston value ddr400 in dual ch sonydru-120c dvd rewriter+liteon 5236 combo +sony cdrom
2 seagate sata2 80gb in raid0 speakers altec lansing mx5021 connected to audiligy2 value this is my htpc as of now i use it as dvd player with my crt tv with component inputs with xpsp2
this system is in lan with my old intel p4 1.7 ghz williamate atop msi 845ge 40gb samsung pata 128ddr266+512ddr400 =640mb ram lg 700s monitor with xpsp2
vivekbabbudelhi is offline
Old 09-03-2007, 01:53 PM   #2 (permalink)
assasin's Avatar
Default Re: lcd monitor with svideo/composite inputs for tatasky help??
the cheapest solution is to buy a external LCD tv tuner card from any good company.It will cost u bout 3-4.5k.In this way u dont hav to switch on ur pc every time u wanna watch tv.
assasin is offline
Old 09-03-2007, 02:09 PM   #3 (permalink)
Does this apply to all external tuners? I am also looking for the same for my 20 inch lenovo.
ranjan2001 is offline
Old 09-03-2007, 02:13 PM   #4 (permalink)
assasin's Avatar
This applies to most external LCD tv tuners from reputed companies (pinnacle ,pixelview etc ).
I've seen PixelView PlayTV Box5.
price : 3-3.3k
But personally i prefer internal ones cuz they allow u to record and timeshift and also allow u to multitask while watching tv.
assasin is offline
Old 09-03-2007, 02:18 PM   #5 (permalink)
So are these features not possible with external ones?
I saw one pinnacle external tuner for 5400/- & it claimed to be having recording facility & time **** but I did not buy it as I am not sure how will time shifting work with STB, since delhi is now under CAS.
Old 09-03-2007, 02:21 PM   #6 (permalink)
assasin's Avatar
i think the pinnacle xternal tuner card ur talkin bout is a USB tv tuner card cux xternal tuners other than USB 2.0 dont hav recording facility.its better to buy a internal tuner than a xternal USB cuz data transfer speeds thru usb prove to be a bottleneck.
theres no reason why recording wont work with STB,just connect the video out from stm to the composite video in of the tuner card.
assasin is offline
Old 10-03-2007, 01:10 PM   #7 (permalink)
shadow hunter
man
that was great for ur quick responsiveness & broad aspect
you own me a one for suggesting standalone external tv tuner
as of my googling i found some from
compro usa
pinnacle
pixelview
PixelView PlayTV Box5.is available with rptech in india
but what about compro as of mediatech they dont sport it at their site
nor is with pixelview
is any body using standalone external tv tuner if so please rate it here
it would be a great help for a shoping spree
or someone from techtree or digit has reviewed
standalone external tv tuners please let us know which of them are available in india
with their prices and picture quality
thanx
