Old 07-03-2007, 11:08 PM   #1 (permalink)
premsharma's Avatar
Default Card Reader Problem in XP
Upon connecting a card reader to PC, I have started getting following problem:
Attrib.exe - No Disk
There is no disk, Please insert disk into drive ... Cancel ... Try agian ...
Error : \dDevice\Hard disk 3\DR 28
This problem persists even after formatting drive. The only way to overcome this error is disconnect the card reader. This problem has been found with allmost every barnd of card reader not anyone particular. So I guess problem lies elsewhere rather than card reader.
Can anyone help me??. Thanks in advance.
premsharma is offline
Old 07-03-2007, 11:18 PM   #2 (permalink)
premsharma's Avatar
Default Re: Card Reader Problem in XP
Sorry but that does not help either
Old 07-03-2007, 11:22 PM   #3 (permalink)
premsharma's Avatar
XP
Old 07-03-2007, 11:23 PM   #4 (permalink)
Prem
1st check if the card reader came with any specific driver, most work with generic XP drivers but I had one earlier that required me to use its own driver else the card would not read.
2nd don't format the card using windows, it has mostly caused problem for some reason, always format either in the camera or other such devices in which u use this card.
ranjan2001 is offline
Old 07-03-2007, 11:29 PM   #5 (permalink)
premsharma's Avatar
These all things have been done. Once the problem was out of my understanding, then only I posted it here. I have now allmost 10 PC with diff configurations, all gives same error, for all the card readers.
Old 07-03-2007, 11:32 PM   #6 (permalink)
premsharma's Avatar
Genuine all
Old 07-03-2007, 11:35 PM   #7 (permalink)
premsharma's Avatar
Crad readers come with drivers for win98 only. Why would XP sp2 needs USB drivers and that's why they are not available.
__________
Originally Posted by shantanu_webmaster
if genuine then UPDATE IT ... by www.update.microsoft.com
have fun
It is updated. You are not able to visualise the problem
Old 07-03-2007, 11:56 PM   #8 (permalink)
try a brand new card then of a different make, does that give the same problem?
Old 08-03-2007, 12:02 AM   #9 (permalink)
premsharma's Avatar
Yes, as i told you that i am facing this problem with brand new and different make of card readers and for past 10 days or so. I have done all my R&D before coming here.
Old 08-03-2007, 12:04 AM   #10 (permalink)
shantanu's Avatar
As i am not able to visualize the problem, so its better to delete all my posts in this thread.. as i dont post to add my post count.. thanks and regards
shantanu
shantanu is offline
Old 08-03-2007, 12:07 AM   #11 (permalink)
No I said not the card reader but the card itself may be the source of the problem, have u used the same card(i mean same brand), if so then alternative is that change them & then see if that solves the issue.
Do u get that error message when u connect the card reader without the card or with the card inserted?
Old 08-03-2007, 12:08 AM   #12 (permalink)
premsharma's Avatar
shantanu
I can not delete those posts of yours. What I meant is that You should not visualise everything from Billu's point of view.
Old 08-03-2007, 12:13 AM   #13 (permalink)
shantanu's Avatar
i didnt say you to delete !!! i deleted them myself.. thanks again... and where does billu come here!! and question will be answered by many people on forum.. Bye.. my last post on this thread..
shantanu is offline
Old 08-03-2007, 12:21 AM   #14 (permalink)
premsharma's Avatar
As you wish. So you have priviledges to delete posts, great achievement
__________
Yeah diff cards have been tried. it comes after connecting card reader, whether, card is there in card reader or not is insignificant. Problem comes with card in or without cards also as soon as the card reader is connected.
Old 08-03-2007, 10:38 AM   #15 (permalink)
assasin's Avatar
Do the card readers work on another pc?
assasin is offline
Old 08-03-2007, 09:40 PM   #16 (permalink)
premsharma's Avatar
same problem on all other pcs with brand new & diff make card reders also
Old 08-03-2007, 10:23 PM   #17 (permalink)
assasin's Avatar
Since all pcs r giving the same prob with card reader den i think deres a prob with the card readers.
assasin is offline
