Old 07-03-2007, 10:27 PM   #1 (permalink)
abhishekkulkarni's Avatar
Default How do you find this HP Laptop ?
My main requirement in choosing this notebook was that I should be able to use Win Vista with Aero and Flip 3D enabled, on it.
What do you think ?
Is it worth the price ( 69K ) ?
Are there any better laptops which willl fit in to my budget of 70K ?
Config HP Pavilion dv6137TX -
Processor - Intel Core 2 Duo T5500, 1.66Ghz, 2MB L2 Cache, 667 Mhz FSB (Intel Centrino Duo Mobile Technology)
Ram - 1 GB DDR2, 667 Mhz (2 * 512 Mb)
HDD - 120 GB SATA, 5400 rpm
GPU - Nvidia GeForce Go 7400, 256 Mb
Display - 15.4", 1280 * 800 WXGA High Definition
Optical Disk Drive - Lightscribe DVD RW (Double Layer)
Communication technologies - 56K Modem, Bluetooth, 10/100 Lan, Intel PRO Wireless 3945ABG 802.11 a/b/g WLAN, 5 in 1 integrated Memory Card reader
Speakers - Altec Lansing
Webcam - HP Pavilion 1.3 Mp VGA camera with integrated Microphone
Remote Control - HP Remote Control
Weight - 2.76 kg
Battery time - 2.5 hours
May the source be with you ..
abhishekkulkarni is offline
Old 07-03-2007, 10:35 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: How do you find this HP Laptop ?
quite good for 69k. A better option would be Asus S96J VBI Laptop from Radington Computers
about.me/gxsaurav
gxsaurav is offline
Old 08-03-2007, 12:25 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
Not a good deal, Dell is cheaper. Go for Inspiron 6400 and configure it according to your needs. Max 60k.
Sourabh is offline
Old 08-03-2007, 12:41 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yeah..dell is offering some cool offer with pre-installed vista home basic.
chk this
http://www1.ap.dell.com/content/prod...n&s=bsd&~ck=mn
ravi_9793 is offline
Old 08-03-2007, 02:08 PM   #5 (permalink)
Abheek's Avatar
Cool Re: How do you find this HP Laptop ?
Not bad at all.
If U buy Digit, just check out the test conducted on 43 laptops in october 2006. If U do not have that issue but have the dec 2006 issue, than check for the PDFS of Digit. If you do not have that either, than give me your emailid and I will send it over.
Abheek is offline
Old 08-03-2007, 04:08 PM   #6 (permalink)
aryayush's Avatar
DO NOT BUY A LAPTOP PRE-INSTALLED WITH VISTA HOME BASIC!
Home Premium is the minimum you should look for.
aryayush is offline
