Re: Upgrade Blues!!!
Currently in terms of performance INTEL C2D hold the upper hand but if you consider price to performance ratio then go for AMD.
And if you are buying AMD then surely get an AMD X2, no point in getting single core processor. But remember all this choices depend on your budget.
So what's your budget?
And I don't think that 8800 series would be outdated by the end of 2007, so if you want and GFX card to be DX10 compatible get yourself 8800 series card. The lowest priced 8 series card is Zebronics 8800GTS 320MB for Rs.19500/- (I think).
But for playing NFS carbon a 7600GT would be sufficient.
And remember one think, whatever component you choose to buy...........please do get a good SMPS like ANTEC, CoolerMaster, Powersafe, Corsair, Zebronics, Seventeam, etc. Don't compromise on this.
