Old 07-03-2007, 12:31 AM   #1 (permalink)
MambaXL's Avatar
Unhappy i m doomed , plz help me
i have upgraded my huawei mt882's firmware to a version dated july 6th 2005. now the problem is my router is mt882 , and after upgrade , it has become mt880. also i m facing many line drops. my network activity gets disconnected frequently.
i should not have upgraded the firmware ( it was june 20th 2005 )
please help me to revert my firmware to the default one.
plz help me
plzz
plzz
plzz
also i have tried those huawei posts in the forum , but the downloaded bin files are not recognized by the control panel of huawei. it says something like invalid file.
plzz help , man , any one
plzz. i m begging you .
MambaXL is offline
Old 07-03-2007, 12:36 AM   #2 (permalink)
assasin's Avatar
Default Re: i m doomed , plz help me
Do u hav a copy of the original firmware?
assasin is offline
Old 07-03-2007, 03:28 AM   #3 (permalink)
Arsenal_Gunners's Avatar
See if this thread helps you..read the second page.
Modems - Advanced Tweaking - ask doubts here
Arsenal_Gunners is offline
Old 07-03-2007, 04:27 PM   #4 (permalink)
MambaXL's Avatar
i dont have the original firmware ?
i have downloaded it from ur forum , but it cant be used. it is in .bin file
what do do now. it doesn't work. invalid firmware upgrade.
MambaXL is offline
Old 08-03-2007, 11:18 PM   #5 (permalink)
MambaXL's Avatar
please help man , i am unable to use those upgrades . it says invalid upgrade file .
__________
please anyone help me . i get . bin files , and when i rename them to .xDSL , it didn't works too.
please help
MambaXL is offline
Old 08-03-2007, 11:31 PM   #6 (permalink)
Maverick340's Avatar
Generally firmware disasters are irreversible. The coding is embedded so either you need the original version , else ..
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 09-03-2007, 03:33 PM   #7 (permalink)
MambaXL's Avatar
can " NO-ONE " in the digit forum help me ?
then plz delete this thread.
MambaXL is offline
