Old 06-03-2007, 07:38 AM   #1 (permalink)
Unhappy HDD about to fail
I have a HP Laptop with WinXP Home, Hitachit HDD...
For the last few weeks, was getting an error that system.ini file is corrupt and hence it wasn't able to load Windows.
I managed to trace back my recovery discs and ran the diagnostics first -- it gave me the below message:
IDE Hard Disk Drive SMART error: drive (Pri Mst)
Your IDE Hard disk is about to fail. Backup your data and Replace the IDE Hard disk.
Can't anything be done now to fix the disk issue?
Is replacing the disk alone the solution?
SGS_001 is offline
Old 06-03-2007, 10:35 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: HDD about to fail
I suggest you to start your backup immediately else you will repent later
techtronic is offline
Old 06-03-2007, 06:38 PM   #3 (permalink)
uchiha.sasuke's Avatar
m also having this prob......for last 8-9 months.....but hdd is working....
uchiha.sasuke is offline
Old 06-03-2007, 06:42 PM   #4 (permalink)
shantanu's Avatar
try updating the MBR of the HDD and Repartitioning it... and if its in warranty take it to service canter as only YOUR HDD is going dead.... TAKE YOUR LAPPY TO SERVICE CENTER..
shantanu is offline
