LinkBack (2) Thread Tools Display Modes
Old 05-03-2007, 02:24 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Ðèåd Måñ Wå£KîÑG
bad_till_bones's Avatar
Default Altec Lansing ATP3 vs Logitech X-230
Guys, pretty much confused btw the two....Altec Lansing ATP3 vs Logitech X-230
Which one is better in all respects....bass, treble n over-all quality?
A comparison(
bass, treble n over-all quality wise) wud b helpful....
Budget is arnd Rs. 2500 /-
Once the game is over, the King and Pawn goes to the same box....
bad_till_bones is offline
Old 05-03-2007, 06:42 PM   #2 (permalink)
Default Re: Altec Lansing ATP3 vs Logitech X-230
logitech x-230 (fdd2 rules)
Faun is offline
Old 05-03-2007, 07:33 PM   #3 (permalink)
shyamno's Avatar
I think Altec Lansing ATP3...will be rocking..
shyamno is offline
Old 05-03-2007, 09:04 PM   #4 (permalink)
Ðèåd Måñ Wå£KîÑG
A comparison(
More advices wud be helpful.... Helpout guys....
Old 05-03-2007, 09:13 PM   #5 (permalink)
crs_cwiz's Avatar
Hey guys, i Have a similar problem too, except that i want a decent 5.1 speaker set for my rig. I have settled for the Logitech X-530 (coz of fdd2 and nonavailability of x-540 in India) but i read in the forums that altec lansing is also very nice.... which one do i go for and wat will they cost me?
Intel C2D E6600 @ 2.7 GHz, 2x1 GB Corsair XMS2 DDR2 @ 900 Mhz, Asus P5N32-E SLI, XFX Geforce 8800 GTS, 2xWD3200KS, WD5000AAKS, Sony DRU-845S, Corsair HX620W, Logitech Z5300, Antec TX1088AMG
crs_cwiz is offline
Old 05-03-2007, 09:51 PM   #6 (permalink)
dOm1naTOr's Avatar
X230 and X530 rulz in case of audio quality as it sports neodimium drivers which produces unmatched quality treble and the subwoofer also is topnotch for the price.
One of my close friend have X530 and is a very good product than my somewhat same priced Creative T6060. Its also better than Altec speakers at that price.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-03-2007, 01:11 AM   #7 (permalink)
Ðèåd Måñ Wå£KîÑG
A comparison(
Guys, plz tell btw these two.....no other choices plz....will add to my confusion
Old 06-03-2007, 02:51 AM   #8 (permalink)
shantanu's Avatar
Smile Re: Altec Lansing ATP3 vs Logitech X-230
Altec lansing is always the best in it class.. + its peak power is better
Altec lansing :
Specifications:
Drivers (per satellite): Two 28mm full range, One 3-inch mid/bass
Driver (subwoofer): One 6 1/2 inch long throw woofer
Frequency Response: 45 Hz - 18kHz
Satellite Power: 12 Watts RMS @ 1% THD
Subwoofer Power: 18 Watts RMS @ 1% THD
Input Impedance: >10K ohms
S/N Ratio: >70 dB
Built-in Power Supply Included
ETL/cETL approved
Features:
High quality, high performance three-piece system delivers powerful audio playback
Two dynamic microdrivers in each satellite deliver all the power and performance of a larger speaker
Down-firing 3-inch mid/bass driver reproduces low-end frequencies for full, rich sound
Speakers are magnetically shielded to prevent monitor interference
Powered wooden subwoofer extends the low frequency response for realistic sound
Separate controls for master volume, bass and treble provide flexibility in sound mix
Slim profile design complements flat screen monitors perfectly
Logitech:
Crank up the audio on your PC with this 2.1 speaker system and enjoy clean, crisp, consistent sound from your games, music, and more.
The Logitech X-230's high-tech subwoofer adjusts itself dynamically to deliver distortion-free bass. And the two wall-mountable satellite speakers use Logitech´s patented FDD2™ technology to eliminate the uneven sound response created by conventional dual-driver designs. The result: a clear, uniform sound field without the "hot spots" and inconsistency of other dual-driver satellites.
Frequency Directed Dual Driver (FDD2) satellite technology produces a uniform sound field for full, rich sound
Dynamic, real-time bass equalization maximizes bass response while minimizing distortion
Ported subwoofer design displaces more air for deeper bass
Headphone jack enables private listening
Master volume and subwoofer level controls placed for quick, convenient access
Satellite speaker stands rotate for easy wall-mounting
Technical Specifications
Total RMS power: 32 watts RMS
Satellites: 12 watts RMS (6 watts x 2)
Subwoofer: 20 watts RMS
Total peak power: 64 watts
Frequency response: 40Hz - 20kHz
Drivers:
Satellites: (2) 2" drivers per satellite
Subwoofer: 5.25" ported driver
Speaker dimensions (H x W x D):
Satellites: 8" x 2.5" x 3"
Subwoofer: 9" x 6" x 9.25"
Signal-to-noise ratio: >96dB
for more info
http://www.logitech.com/index.cfm/pr...CONTENTID=9066
shantanu is offline
Old 06-03-2007, 02:53 AM   #9 (permalink)
gurujee's Avatar
atp is around 2500 or more ?????ebay listed the same for 3100 including shipping ???and is there any chance of duplicate in altec product ..there is duplicates of creative everywhere
gurujee is offline
Old 06-03-2007, 06:35 AM   #10 (permalink)
shantanu's Avatar
there can be duplicate in everything.. even my comp. discovered he had a duplicate thats me
joking
shantanu is offline
Old 06-03-2007, 09:54 AM   #11 (permalink)
Ðèåd Måñ Wå£KîÑG
Thnx a lot Shantanu, but don't u think Logitech takes an edge over Altec Lansing ATP3 according to the configurations tht u mentioned above....
Old 06-03-2007, 10:31 AM   #12 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
I havent heard the Logitech but own the Atp3, by far the best speakers i ever owned ,iam absolutely satisfied with these speakers. Throw movies ,music ,HD vids at it and it plays relentlessly. I especially love the woofer.
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 06-03-2007, 11:08 AM   #13 (permalink)
gurujee's Avatar
joking
he he he
__________
i agree, after seeing atp has won in digit test this month
gurujee is offline
Old 07-03-2007, 06:40 PM   #14 (permalink)
crs_cwiz's Avatar
well, it has won the test, but if you notice properly, x-230 has a higher performance (highest, in fact) for a few hundred bucks more.. as for 5.1, even the logitech speakers weren't reviewed, including the z-5500. perplexing...
By, the way guys, what abt a z-5300, is it nice? My dealer told me to spend some more money and get a thx certified speaker set. He quoted the Logitech z-5300 at Rs. 11250/-. Is the deal nice??
crs_cwiz is offline
Old 07-03-2007, 08:27 PM   #15 (permalink)
dOm1naTOr's Avatar
The prics shud have benn some 500 bucks less, but seems ok, as price changes from place to place.
Z 5300 is one of the mindblowing speaker at that price range. It has 280w RMS nd only heard 'GR8' from every reviews i read. Its clarity come close to Z 5500, but at lower power.
G3: XPS M1530 |
FZ 16.
Old 09-03-2007, 02:36 PM   #16 (permalink)
crs_cwiz's Avatar
Finally got the z-5300, it's huge, but as you rightly said, mind blowing!!. My windows really shook with this system. Thanks guys!!!
BTW.. I'd really go for Logitech X-230 if i had to make a decision...
crs_cwiz is offline
Old 09-03-2007, 03:50 PM   #17 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
I bought Logitech R-20 spks
ssdivisiongermany1933 is offline
Old 09-03-2007, 06:17 PM   #18 (permalink)
How much they cost u ?
And are they with subwoofer ?
Faun is offline
Old 09-03-2007, 08:56 PM   #19 (permalink)
Ðèåd Måñ Wå£KîÑG
Guys, today went out to take a demo of both the speakers - Altec Lansing ATP3 vs Logitech X-230.
Might b the surrounding difference of the shop's or anything, but found the bass of Logitech X230 more superior than Altec Lansing ATP3. However, also felt that the Logi one was giving bass on everything, even on those where it was not really needed.....
One thing more, the Altec Lansing sub-woofer, that has a speaker opening at the bottom, was kept on a 1-2 inch thick glass. Can this b the reason of its low bass, as glass acts as a good sound absorber.......plus the Altec Lansing shop was pretty much crowded (both instruments + ppl) and the Logi one was a hall type n total empty (mentioning this, if it can help in telling the sound difference tht I felt). Pretty much confused really.....
Old 09-03-2007, 09:26 PM   #20 (permalink)
String Phreak
mediator's Avatar
ATP has won becoz of its price. I suggest u read the pages again carefully! I dont trust Digit's comparison in this regard!
Its the latest/march edition and they gave the price as Rs. 3400 for Altec Lansing ATP3 whereas my brother bought it for Rs.2400 and that too in december! Recently I bought "altec lansing 151i" 5.1 speakers. I bought it for Rs.2800 and performance is rock solid!
My cousin has ATP3. The sound is excellent. I find both ATP3 and 151i same on 2.1 mode, but when the surround mode is enabled on 151i, then its simply amazing!
Not sure, but the price of ATP3 was around 1400 bucks!
mediator is offline
Old 09-03-2007, 10:05 PM   #21 (permalink)
Ðèåd Måñ Wå£KîÑG
Guys, any comments on the above.... help me out
Old 09-03-2007, 10:08 PM   #22 (permalink)
shantanu's Avatar
as i said you before also go for altec lansing...
shantanu is offline
Old 09-03-2007, 10:12 PM   #23 (permalink)
Anindya's Avatar
Talking Re: Altec Lansing ATP3 vs Logitech X-230
I bought Altec Lancing ATP3 on 5th of March. It Cost me Rs.2756 in Kolkata. It is totally worth the money or may be more. But dont know about the other.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 10-03-2007, 12:53 AM   #24 (permalink)
Altec Lansing ATP3 - 2.1 Rs 2550 @ deltapage.com
Old 10-03-2007, 01:30 AM   #25 (permalink)
t159 , i bought them for 1100 from nehru place delhi ,they are with subwoofer
Old 10-03-2007, 01:42 AM   #26 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Get an ALTEC LANSING ATP3.........have been using these for around 1 year ago. Good looks and great performance. One suggestion, if possible hear to a demo of both speakers (do take favourite music CD with you) and then decide.
Nothing better to judge with than your own ears.
john_the_ultimate is offline
Old 10-03-2007, 10:12 AM   #27 (permalink)
Ðèåd Måñ Wå£KîÑG
Guys, thnx for ur suggestions, seems I have finally made my mind to get Altec Lansing ATP3....
Anyways, just one query, wht is the best place to keep a sub-woofer? And is it advisable to keep the sub-woofer on a glass (1 - 2 inch thick)?
Thnx again....
Old 10-03-2007, 11:14 AM   #28 (permalink)
No pain....No gain
Best keep on the floor..........at the corner but since the woofer of ATP3 is down firing, you can place it anywhere on the floor.
Old 10-03-2007, 11:21 AM   #29 (permalink)
gmanog's Avatar
I bought my ATP 3 for 2400 rs from RP Tech, chennai.
gmanog is offline
Old 10-03-2007, 12:00 PM   #30 (permalink)
Ðèåd Måñ Wå£KîÑG
And is it advisable to keep the sub-woofer on a glass (1 - 2 inch thick)? or will it rather absorb the sound and make the effect weaker????
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/51463-altec-lansing-atp3-vs-logitech-x-230-a.html
Thread Altec Lansing VS4121 vs Creative Inspire T3100 vs Logitech X-230 | Digit Forum | BoardReader This thread Refback 13-03-2011 09:21 AM
2.1 Music Speaker system for under ~3.5K This thread Refback 21-08-2010 12:59 PM
