Old 04-03-2007, 09:52 PM   #1 (permalink)
Default diffy btw core duo etc...
wats the diff btw core duo, core 2 duo, centrino, 64 bit etc etc...
U r a teen ???
www.allteenforums.com
bugmenot is offline
Old 04-03-2007, 10:01 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: diffy btw core duo etc...
google it or check wikipedia...
Pathik is offline
Old 04-03-2007, 10:29 PM   #3 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
basically core duo is for laptop , core 2 duo is for desktop , both are 64 bit .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 04-03-2007, 10:50 PM   #4 (permalink)
Google Bot
Pathik's Avatar
core 2 duo is available in lappys also...
Pathik is offline
Old 04-03-2007, 11:05 PM   #5 (permalink)
premsharma's Avatar
Then what is diff between Dual Core & Core 2 Duo? Core 2 Duo is also dual core.
premsharma is offline
Old 05-03-2007, 10:12 AM   #6 (permalink)
assasin's Avatar
All laptop proccy having the Yonah core r called core duo.
For difference bet core duo & core2duo see attachment
Source:AnandTech
Link:http://www.anandtech.com/cpuchipsets...spx?i=2808&p=4
assasin is offline
Old 05-03-2007, 11:56 AM   #7 (permalink)
C# Be Sharp !
dual core means having two cores , basically like 2 processors in one package , core 2 duo comes under category od dual core , AMD also has a dual core lineup and also Pentium D is dual core .
Old 05-03-2007, 01:11 PM   #8 (permalink)
premsharma's Avatar
That is what I have been exactly requesting difference between PD dual core and Core 2 Duo. They both are dual core, isn't it?
If dual core means having 2 cores, then what does C2D means??
Old 05-03-2007, 05:43 PM   #9 (permalink)
Google Bot
Pathik's Avatar
core duo is used only in laptops...
also all proccys having the yonah core r core duos andd tose wit the conroe core r c2ds.. and c2ds > core duos..
Pathik is offline
Old 05-03-2007, 08:53 PM   #10 (permalink)
18 Till I Die............
Intel Core Platform - http://en.wikipedia.org/wiki/Intel_Core
Intel Core 2 Platform - http://en.wikipedia.org/wiki/Intel_Core_2
Pathiks are you sure Core Duo is used only in Laptops?
http://www.bash.org/?258908
mehulved is offline
Old 06-03-2007, 12:56 AM   #11 (permalink)
assasin's Avatar
Afaik core duo is used only in laptops
assasin is offline
Old 06-03-2007, 10:38 AM   #12 (permalink)
EagerBeaver's Avatar
Nice knowledge Thanks.
FREEDOM ROCKZ...ATTITUDE RULZ
EagerBeaver is offline
