Old 04-03-2007, 02:04 AM   #1 (permalink)
Default Chip (Electronics) Question
Hello. First, please see attachment. I noticed this from a graphics card. Primarily as a matter of curiosity I'd like to know a) What the purpose, in general, a circuit part like that does (for instance, is it some type of capacitor or current regulator?), b) what could cause it to be damaged like that, and c) what is that discolored fluid-looking substance there?
Thanks.
AstroD is offline
Old 04-03-2007, 09:35 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Chip (Electronics) Question
well from the look of it it seems like the coolant solution tht is usually applied between the processor and heat sink to help the procy to cool
http://beingmanan.com
iMav is offline
