Hello. I have a Trinitron CRT monitor, purchased in 1999. The screen image either a) compresses vertically before jumping back to normal, and/or b) sometimes scanlines appear at the lower bottom third of the screen. Often, the screen image is normal; the problem occurs at random intervals. I'm not sure if the problem is computer related or monitor related. There is no magnetic interference nearby. I am using a computer powerbar and everything is grounded. The computer itself seems to be functioning fine. Attempting to isolate the problem, I changed my graphics card (from an ATI XPERT 128 16MB card to an ATI Range 9000 64MB card) and dusted the inside of the computer but this has not fixed problem. I thought the problem may be heat induced so I cleared away anything that was near the monitor; this seems to have had little effect--expect perhaps slightly reduce the frequency of the occurances. Average room temperature with the computer on is 26-30°C. I did swap my CRT with a funtioning LCD display. There were no problems using the LCD other than parallel diagonal lines that moved from right to left and a peppered static-like haze, similar to traditional tube TVs. The LCD was really cheap and I determined that lowering my video card's refresh rate resolved the display problems with the LCD. I tried using my CRT on another computer and there were no problems as far as I am aware; it is worth noting that the other computer was in a different room which had an average temperature of 23°C. Some people suggested the problem may be due to my power supply which they thought might be overheating due to dust or not being able to supply enough power to all the computer devices. I'm not sure if the problem is the power supply or the monitor. Lastly, I'm not sure if this is important but when I maximize all windows from a minimized state the boundary edges of the screen image move slightly and then stay put. I would appreciate any help. Here are some additonal specs:
My Computer Specs:
ASUS P3B-F Jumperfree ATX Motherboard Revision 1.03 with Intel 440BX AGP Set
Intel Celeron Processor
Computer speed currently 900MHz (100MHz bus)
640MB SDRAM
BIOS Revsion 1006
Range 9000 64MB AGP Video Card on 2x AGP bus
Power Supply:
-- Touch Switching Power Supply
-- AC I/P: VOL: 115/230V~CUR: 5/3A MAX. FREQ: 50-60Hz
-- Model: ATX-50A
-- DC O/P: 250W, +3.3V: 14A, +5V: 18A, +12V: 9A, -5V: 0.5A, -12V: 0.5A, +5VSB: 1A
Currently attached devices:
-- 2 hard drives
-- 2 optical drives
-- 1 floppy drive
-- 1 chassis fan
-- 1 ISA ethernet card
-- 1 PCI sound card
-- 1 PCI modem
-- 1 PCI Promise Ultra133 TX2 IDE adapter
ART A-701T
-- Max Supported Refresh Rate: 120 Hz
-- Max Resolution: 1920 x 1080
Current Video Card Refresh Rate and Resolution:
-- 100 Hz
-- 800 x 600
Operating System: Windows XP SP2
Current motherboard readings from ASUS Probe:
-- CPU Temperature: flucuates between 45-51°C, 107-123°F
-- Motherboard Temperature: 33°C / 91°F
-- CPU Fan: 3629 rpm
-- Voltages:
-- +12V fluctuates between ~11.8 and 12.032 V
-- +5V ~4.838V
-- +3.3V ~3.44V
-- Vcore at 1.744V
