Old 03-03-2007, 08:54 PM   #1 (permalink)
Question Worthy 2 buy a a dvd writer?
guys, i hav a celeron machine @500mhz and 128mb ram
will a dvd writer work on my system smoothly?
and if not wat do u think is it worth a buy at the given speed lag???
i found out that the guys at lamington sell the same make same model for 1700-oem and 1950-box pack n say that the same period of guarantee applies 4 both
so watz the difference?
Geeked Out!!!
dhairyadand is offline
Old 04-03-2007, 12:34 AM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Worthy 2 buy a a dvd writer?
sony/hp/liteon/asus are good
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 04-03-2007, 12:53 AM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
n also which dvd rw make is good.
thanks
DVD writer would work smoothly, though a piece of advice...do not run any other application while burning.
Liteon/Sony are the best stay away from samsung/LG
sam9s is offline
Old 04-03-2007, 01:32 AM   #4 (permalink)
nach p's Avatar
thanks
dvd writer will work but
main prob is lower RAM ,burning a dvd will take 2 much time (maybe min45-50min
)better upgrade RAM and have a nice dvd r/w
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 04-03-2007, 02:19 AM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
RAM has little to do with Burning speed.....
sam9s is offline
Old 04-03-2007, 01:03 PM   #6 (permalink)
Shasanka_Gogoi's Avatar
It will work, but try upgrading ur RAM, or else it may lead to frequent burn errors.
Shasanka_Gogoi is offline
Old 04-03-2007, 01:53 PM   #7 (permalink)
nach p's Avatar
I have experience of dvd r/w on 256 ram on p3
better upgrade ram
-Dennis Ritchie
nach p is offline
Old 04-03-2007, 02:04 PM   #8 (permalink)
dOm1naTOr's Avatar
Yes the burning software extensively uses ram to cache while burning a DVD at max speed. he should be able to burn discs successfully if he close all other applications nd burn at 4x speed or lesser. But it would take hell of a time.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-03-2007, 02:20 PM   #9 (permalink)
Google Bot
Pathik's Avatar
dude u hv a very low config.. 1st get a better config and then a dvd writer
Pathik is offline
Old 04-03-2007, 02:32 PM   #10 (permalink)
The High 5 Flyer
sam9s's Avatar
better upgrade ram
Leme rephrase what I wrote. I guess I should have put it in a better way. More RAM does not dictate the burning speed, your writer can still burn on higher x even if your ram is 64, the point is we might run the risk of getting Buffer underrun problem which is...
when the processor is slow in supplying data enough to the writer for it to record the data properly, this can happen when you are running multiple applications at the same time while burning on a not so fast computer.
To avoide this writers usualliy have a buffer but if you have a too slow computer or too many applications are running the buffer will run short of data. To avoide this its adviced to burn the disk at lesser X. In this way CPU will only have to send half as much data to keep the buffer full, making the whole process less sensitive to errors..............
sam9s is offline
Old 04-03-2007, 02:40 PM   #11 (permalink)
dOm1naTOr's Avatar
A DVD at 16 burns data at 22MBPS. Its very high speed and its sure to go buffer under-run of old PCs if burned at 16x. So u should first allocate the maximum ultrabuffer on Nero 7 and close all other apps. The disc is more prone to error when burning the last secsions, ie after 50 or 60% as according to constant aggular velocity(CAV) recording the burning gets max speed(upto16x) at the eye moves to end or outer edge of disc. So better choose 2x. But surelly u can burn DVDs.
G3: XPS M1530 |
FZ 16.
Old 06-03-2007, 11:25 PM   #12 (permalink)
thanks guys
do u think increasing the page file size wud do any gud???
n also difference between oem product vs box pack
Geeked Out!!!
Old 07-03-2007, 12:31 AM   #13 (permalink)
The High 5 Flyer
sam9s's Avatar
^^ Better not touch the paging file size (Your computer might start behaving quite irratically if the ratio is messed with), instead I suggest you better go by the suggestions posted my arvind or me.....
sam9s is offline
Old 08-03-2007, 02:17 PM   #14 (permalink)
Abheek's Avatar
Well, the difference is that the boxed writer is original, and the other one is pirated(duplicate). Always insist on original products, be it software or hardware. Original software and hardware are safer and offer better performance8)
Abheek is offline
Old 08-03-2007, 07:01 PM   #15 (permalink)
gurujee's Avatar
dont buy SAMSUNG. I had in oct06 and it started giving slow reading in december..
gurujee is offline
Old 08-03-2007, 07:14 PM   #16 (permalink)
The Unknown's Avatar
These guys said doubtly about a dvd writer on my machine which is p3 500. Celeron is junior to p3. it\'s ur wish. i hv not bought that dvd rw.
KDE on ArchLinux
The Unknown is offline
Old 08-03-2007, 09:45 PM   #17 (permalink)
my configuration, pentium 1.8 Ghz, Ram 256 Mb. will I be sutiable for DVD witer.? Guys, Please also mention whiuch MODEL NUMBER i should buy!! thnaks!!
torrent08 is offline
