Old 01-03-2007, 06:37 PM   #1 (permalink)
Default starting problem
hi friends,
i have got problem with starting the system. whenever i start the sytem 5 out of 10 times it give me message "Boot & select proper boot device or insert boot media in selected boot device" but when i close and then start the system it runs fine. can i know what could be the problem
Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
kunaltech is offline
Old 01-03-2007, 06:53 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: starting problem
^^These symptoms clearly indicate that the system has gone NUTS.
Btw. What has been configured as the primary boot device in your bios?
Arsenal_Gunners is offline
Old 01-03-2007, 07:52 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by kunaltech
hi friends,
This seems to be a hardware issue, either the hard drive or motherboard is not functioning as it should.
firstly doing anything...enter BIOS....check ur BOOT order..
if this doesnt helps..if u can ..only if u can update ur BIOS...there could be problem due to corrupt BIOS...
Next if this does not helps check ur HDD cables...
Lastly u can
Reformat, and reinstall the operating system.
If this is not helping then.....
It can happen due to many reasons too...like power supply having problem...get new one...if not that then HDD is gona die..u will have to get new one...happy HUNTING
wizrulz is offline
Old 01-03-2007, 07:56 PM   #4 (permalink)
chahal63's Avatar
hi friends,
just check your ide cables and boot device prority
chahal63 is offline
Old 01-03-2007, 08:05 PM   #5 (permalink)
Security Exp
47shailesh's Avatar
@chahal63
R U A ONE WORD EXPERT...
GIVING THE ANSWER IN SINGLE WORD WHICH OTHER HAD ALREADY MENTIONED..
AVOID THESE PRACTISE
We Love Once, And When We do We do it Well
47shailesh is offline
Old 03-03-2007, 12:09 AM   #6 (permalink)
hi friends
i have checked all the data cables and have cleaned the ram and other things but it dint work out. now when system restart automatically that time i press power button and shutdown the system but it starts automatically then i have to shutdown from windows and it shut down properly
Old 03-03-2007, 02:07 PM   #7 (permalink)
TooR
alok4best's Avatar
hi friends
Didnt understand what u r trying to tell..please write more clearly..preferably in smaller senteces..and yes it will be great if u plug out and plugin back all cables..like power,IDE,Sata(if any)...
check the condition of power supply..
then check ur BIOS setting
Recommended boot order
1st-CD-ROM
2nd-HARD DRIVE
save and exit...restart and again check that the settings that u made are sustaining or not..like after u changed the boot order does it again revert back to something else...if its the case then try chaging motherboard's battery..if the problem still persists,contact ur hadware vendor..
I wish !!
alok4best is offline
Old 03-03-2007, 02:15 PM   #8 (permalink)
Too hot for this forum.
i think its a PSU problem.maybe something wrong with the molex conectors.
Life's too short.Why use Dialup?
s_aerin is offline
Old 08-03-2007, 10:45 AM   #9 (permalink)
hi friends
thanks for ur suggestion the problem is solved their was some problem with smts
