keith
try running with either RAM one by one and check .
also try interchanging the RAM sticks.
also check in BIOS if your RAM is working in dual mode or not.
This will let u know where the problem is .
sridatta:
u want to try SDRAM in combination with DDR..
and i dont think they wud ever be compatible..u can experiment always..no prob will occur to the pc.
but u can definitely install two more same 256 mb ddr sticks ,they will work in dual channel mode in pairs giving a slight more performance boost.
price 256 mb RAM: 900-1200 rs simtronics.
kingston:around 1400 rs here in agra.
reps are a gud way to give thanx
