01-03-2007, 11:09 AM
Suggest me amd cpu+m/b combo
I want to buy an amd-based system. which model should i go for. i am confused. amd athlon 64 stands for what? 64-bit cpu? i dont think i need 64-bit. then there are different 'pin'-s - which one should i pick.
and what motherboard will be ideal.
Nipon
01-03-2007, 11:23 AM
GUNNING DOWN TEAMS
Re: Suggest me amd cpu+m/b combo
BUDGET
01-03-2007, 11:27 AM
hmm... what does that mean?
Nipon
01-03-2007, 11:29 AM
GUNNING DOWN TEAMS
WHAT IS UR AGE???...  ..no no budget does not means that just like that....
BUDGET means how much money can u spend on mobo and processor...  ...
01-03-2007, 02:22 PM
Processor AMD X2 4200+ at Rs 7000+ at deltapage.com
01-03-2007, 02:59 PM
Can u give ur budget. If its on the tighter side u can go for the Sampron platform, they are really good.
01-03-2007, 11:42 PM
oh! well i want a balance between price and performance...i want an amd cpu that is at par with the intel c2d. however i dont need 64-bit i think.
Nipon
01-03-2007, 11:50 PM
The High 5 Flyer
^^any specific reasons for AMD CPU that is at par with C2D. Why not C2D it self. Would that be out of your budget?
02-03-2007, 12:26 AM
If u want AMD only then get a gud proccy like the X2 5000+ or above. They are really good, but never go for FX as they have very low value for money.
for eg; X2 6000+ beats FX 62 but X2 is much lower priced.
G3: XPS M1530 |
FZ 16.
02-03-2007, 12:29 AM
GUNNING DOWN TEAMS
do not beat around bush...just say ur budget,.....
02-03-2007, 01:28 AM
Because C2D is costly as well as there is no motherboard for intel platform with onboard graphics other than intel GMA 3000. ATI is sleeping. Their mobos for intel {1250 & 3200 chipset based] will yet take 4-5 moths to appear in market.
Therefore, no other choice but to think about AMD equivalent.
02-03-2007, 01:49 AM
Rising ApocalypsE
Dude this message has been on & on so the straight forward is HOW MUCH MONEY IS YOUR DAD IS GIVING U TO BUY A COMPUTER?
Obviously u don't need a 5000+ or 6000+.So say those magical words!!!
02-03-2007, 02:28 AM
18 Till I Die............
And why don't you want a 64 bit computer? Whole world seems to be moving towards 64 bit, slowly but surely and you still want to invest in 32 bit?
BTW, C2D's are 64 bit too.
See, if you give the amount you're ready to put in, then people can get an idea about what to suggest for you. Otherwise they'll just be shooting in the dark.
http://www.bash.org/?258908
02-03-2007, 02:35 AM
Even sempron is also AMD 64 technology .. so this aint possible
02-03-2007, 12:52 PM
He is a noob duns. He dont know about 64-bit.
Hey superhero, grasp this - every new pc u'll buy will be only 64-bit. But dont scare urself to death cos the news u wud have read about 64-bit drivers, issues etc. n incompatibility wont arise until u install 64-bit OS.
Just install 32-bit OS n u'll be havin 32-bit experience. Safe n sound.
02-03-2007, 01:43 PM
Google Bot
dude 64bit is fully backward compatible wit 32bit... so wats the prob??
02-03-2007, 08:41 PM
The High 5 Flyer
There are n number of options given the budget, and C2D is not at all costly given the fact its a 64Bit Kick Ass true dual core.
And why think about an onboard card when you can get any 6 series dedicated graphic solutions decently inexpensive. Heck you can even get an FX5200 which plays HL2 effortlessly. I am no anti AMD but presently no processor can give you better price :::: performance ratio than a 6300 or even a 6320.
03-03-2007, 01:11 PM
See ATI X300SE PCI-E from palit @ 2000+ can give you better than 6600 even
