Old 28-02-2007, 08:23 PM   #1 (permalink)
Question internal+USB
is it possible to use an internal dvd writer as an usb writer by using USB HDD case ?
bharatesh is offline
Old 28-02-2007, 08:47 PM   #2 (permalink)
Default Re: internal+USB
I dont have the answer, but wonder why would u do such thing?
ranjan2001 is offline
Old 28-02-2007, 08:59 PM   #3 (permalink)
Google Bot
Pathik's Avatar
nopes
Pathik is offline
Old 28-02-2007, 09:01 PM   #4 (permalink)
i have 2 writers ( sony & lite-on) , 2 sata HDD ( samsung 80gb 7 WD 250 gb)
one IDE HDD ( seagate 40 gb ) ! My mobo has only one IDE port , alrady occupied by liteon writer & seagate HDD.
Old 28-02-2007, 09:01 PM   #5 (permalink)
The Unknown's Avatar
tried cdr. worked @ 52x.
KDE on ArchLinux
The Unknown is offline
Old 28-02-2007, 09:52 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
Which mobo have you got, If its like a 845, 850 series you should be having two IDE cables to connect any 4 peripherals in any combinations.
Or else you can use IDE to USB converter to connect your IDE HDD externally.
Its something like this...
https://www.sirindia.com/details.asp?productID=10123577
http://www.the-gadgeteer.com/review/...able_version_2
Would cost you around 300 Bucks for the set (NP Delhi)
sam9s is offline
Old 28-02-2007, 10:00 PM   #7 (permalink)
my mobo is 965RY . it has 4 sata , 6 usb & only 1 IDE port
Old 28-02-2007, 10:28 PM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
mmmmm is there a need to connect two writers? or you can probably try that IDE to USB connection with a writer, see if that works. It works with IDE HDD well that I know.
sam9s is offline
Old 01-03-2007, 02:54 PM   #9 (permalink)
Shasanka_Gogoi's Avatar
Of course it is. U can go for an IDE to USB converter for around 350 bucks or else invest in an external casing for around 800 bucks.
Shasanka_Gogoi is offline
