Old 28-02-2007, 12:42 PM   #1 (permalink)
yesh1683's Avatar
Angry My new system doesnot boot from DVD disk?? please help me out
Just a month back i bought an new PC my config is
Intel DG965RY mobo
Intel core2 duo E6300
160 GB SATA seagate
Sony DVD Rewriter
1 GB DDR2 533 MHz x2 running in dual channel
I Purchased windows vista ULTIMATE DVD and I tried to boot from the DVD to install fresh OS, but my system doesnot boot from That dvd it simply restarts normally,, i have set boot device priority 1st boot to DVD RW and second to HD,, however my XP cd boots fine,,, The vista DVD runs from windows environment
I checked vista DVD in my friends PC it boots fine
I made my XP cd iso, and then burnt to DVD and tried to boot that, again it doesnt boot,, [this dvd booted in my friends pc]
My sytem boots from CD normally
but my sytem doesnot boot from any dvd
Wats wrong with my system?/ where does the real problem lies???
My vendor doesnt know anything abt it???
I have updated the bios version to latest 17th jan but the problem didnt solved
Guys i am really Afraid
will my problem be solved??,, this really cracking my head
Please Help me guys,
Hoping for prompt reply
yesh1683 is offline
Old 28-02-2007, 01:01 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: My new system doesnot boot from DVD disk?? please help me out
before suggesting anything I will ask u to:
Take out ur DVD drive and install it on ur friend PC...than post the result here.We will definetly help u,but first do this.
ravi_9793 is offline
Old 28-02-2007, 01:28 PM   #3 (permalink)
yesh1683's Avatar
Thanx dude i will check it in the evening and post the result
yesh1683 is offline
Old 28-02-2007, 01:31 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
u welcm dude.I m always there to help.
Old 01-03-2007, 08:03 PM   #5 (permalink)
chahal63's Avatar
i have the similiar problem but it dosent get working with ravi solution.
chahal63 is offline
Old 01-03-2007, 11:37 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
what hit and trial methods U have tried till now.Please post all .Than only I can sugeest you anything.
Old 02-03-2007, 12:14 AM   #7 (permalink)
dOm1naTOr's Avatar
@yesh1683
keep pressing F8 key during post ckeck screen(not during OS selection) nd u will be prompted to select the boot device like CD ROM, DVD, HDD, lagacy lan etc...most mobos would boot from DVD only in this manner.
Is it Vista DVD?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 02-03-2007, 03:56 PM   #8 (permalink)
yesh1683's Avatar
I was not able to remove my drive myself so i took the system to my vendors shop and there he removed my drive and installed another dvd rom and it booted fine
so my problem was with my dvd writer
Oh!! atleast i can breath easy now
I have asked for replacement, my vendor told that he will give another one within 2 days
__________
Originally Posted by aravind_n20
@yesh1683
Is it Vista DVD?
That method didnt work on my PC,, I saw that option on my friends asus board & that feature is quite useful
AND yes its VISTA ULTIMATE DVD
yesh1683 is offline
Old 02-03-2007, 04:07 PM   #9 (permalink)
Google Bot
Pathik's Avatar
that method differs from bios to bios....
Pathik is offline
