Re: system restarting
i m not allowed to check yaar . but will try to see and let u know
can u tell me what can be other resons so that i can cjeck with all posibilities
if smts is not good can it create a problem like this
nope i dint added any new hardware
it was running fine abd suddenly its happening since 20 days
i neglected may be coz it might be geeting losse from switch board but when check all where fine .
Once a new technology rolls over you, if you're not part of the steamroller, you're part of the road
